Best chains for mud??
/ Best chains for mud?? #2
I work for a chain manufaturer up in Kamloops (we have a sales branch in Langley)....
I can't say one will work better than another, because eventually they will all clog up with mud... but if you have a v-bar or studded, it will probably be the best.
What kind of machine are you using it on? if it is a midsize tractor, you could use duo grip... it's a H-pattern
/ Best chains for mud?? #3
Related Question (hopefully) and not a "hi-jack":
I understand that R-1's (Ags) are best for mud.
However, I like turfs.
In the event that I have to "go mudding," sometime, I am interested in opinions on which is better in heavy mud, and by how much:
Unchained R-1's vs. Chained Turfs?
I've read that turfs are better on pavement, with snow (more surface area, in terms of more lug faces [and, consequently, lug-surface area], on the ground at the contact patch, than R-1'a or R-4's, due to the turfs' greater number of smaller lugs, wider cross-section, and softer composition/(less plys?). I've also read that turfs' superiority on pavement, in snow, is definitely enhanced with chains, and actually exceeds the traction of R-1's (and possibly R-4's), even if the latter two are chained up, due to the wider-spaced ribs inability to match the "greater surface-area contact patch" of turfs, on a hard, snow surface.
However, I just wonder how much I may be able to compensate for turf's (generally-acknowleged) inferior ability to handle mud, if I were to add chains to the turfs, in the future?
Machine contemplated is a cabbed B3030, for gardening and general property maintenance, on 2-4 acres.
Thanks,
My Hoe
/ Best chains for mud?? #4
All the log skidders that I have seen working on muddy ground were using ring type chains.
L 35 TLB
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
RoGator RG1300C (A63688)
RoGator RG1300C...
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
