Best chains for mud??
/ Best chains for mud?? #2
I work for a chain manufaturer up in Kamloops (we have a sales branch in Langley)....
I can't say one will work better than another, because eventually they will all clog up with mud... but if you have a v-bar or studded, it will probably be the best.
What kind of machine are you using it on? if it is a midsize tractor, you could use duo grip... it's a H-pattern
/ Best chains for mud?? #3
Related Question (hopefully) and not a "hi-jack":
I understand that R-1's (Ags) are best for mud.
However, I like turfs.
In the event that I have to "go mudding," sometime, I am interested in opinions on which is better in heavy mud, and by how much:
Unchained R-1's vs. Chained Turfs?
I've read that turfs are better on pavement, with snow (more surface area, in terms of more lug faces [and, consequently, lug-surface area], on the ground at the contact patch, than R-1'a or R-4's, due to the turfs' greater number of smaller lugs, wider cross-section, and softer composition/(less plys?). I've also read that turfs' superiority on pavement, in snow, is definitely enhanced with chains, and actually exceeds the traction of R-1's (and possibly R-4's), even if the latter two are chained up, due to the wider-spaced ribs inability to match the "greater surface-area contact patch" of turfs, on a hard, snow surface.
However, I just wonder how much I may be able to compensate for turf's (generally-acknowleged) inferior ability to handle mud, if I were to add chains to the turfs, in the future?
Machine contemplated is a cabbed B3030, for gardening and general property maintenance, on 2-4 acres.
Thanks,
My Hoe
/ Best chains for mud?? #4
All the log skidders that I have seen working on muddy ground were using ring type chains.
L 35 TLB
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
CASE INTERNATIONAL 21' FIELD CULTIVATOR (A63291)
CASE INTERNATIONAL...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2011 Isuzu NRR Dovetail 22ft. Flatbed Truck (A61573)
2011 Isuzu NRR...
