best attachment for 20"+ rocks
/ best attachment for 20"+ rocks #1
Anonymous Poster
Epic Contributor
best attachment for 20\"+ rocks
Bobcat recently came out with a "Digger" attachment. This simple tool looks like it would work great for removing larger rocks and smaller stumps as well as for trenching. There is a video on the Bobcat web site. My question is whether there is anything comparable for a compact tractor. Has anyone used the Digger? I'm seriously considering a 753 Bobcat instead of a tractor just because of this attachment, which will avoid the expense of a backhoe.
/ best attachment for 20"+ rocks #2
Re: best attachment for 20"+ rocks
alf - I believe if you go with a NH compact with the quick attach loader you can use many of the skid steer attachments. I'm not 100% sure about the 'digger' but I would assume it would work. Does it resemble a backhoe in looks?
I'm currently eyeing a TC35 with the 16LA loader which I can get the quick attach set-up for $250-$300. It seems to be a very worthwhile investment for the amount of flexibility it gives you. I'm looking at getting it for the pallet forks and, of course, the HD bucket. That way you can have your cake and eat it too! Hope that helps!
Sam - Tractorless in Big 'D'
/ best attachment for 20"+ rocks #3
Re: best attachment for 20\"+ rocks
alf
I looked at the bob cat site. I liked the digger, that could come in handy at times. have you priced it? I have a GB loader on my JD 4300 with quick tacth bucket, so any QT bob cat attachment fits. I got pallet forks (bobcat) for $600 and JD was $900. it is nice to have options.
/ best attachment for 20"+ rocks #4
Alf, With no back on the Digger like a typical bucket I think unless you were in thick gummy soil you would loose most of the dirt that you were trying to get out of the hole. Also remember that instead of swinging the dirt to the side onto the spoil pile you would have to back up, turn and go forward, dump, back up, turn and go forward for every scoop you take. All that motion would tend to shake a lot of the dirt out of the scoop area. With the digger I bet you would spend an awful lot of time cleaning out the bottom of the hole/ditch with a hand shovel. As for stumps, I think it would only be good for the smallest stumps as a backhoe has much more break out force than a bobcat would be able to attain due to traction problems. I could be grossly wrong in my judgement without having seen it work in person, but I have spent enough time on a backhoe to know that I would become frustrated rather quickly if there was no back to the bucket. The digger kinda reminds me of a 3 pt scoop without the back. After giving it some thought it might work better to convert a scoop to front end loader use. You would have to rig some kind of an extension to get it further from the lift arms as in the digger's design.
Jimmy
/ best attachment for 20"+ rocks #5
I added the "Quick Attach" being discussed to my Ford (NH) 2120 after 12 years of use- I have a bucket, Woods forks and a rock screening bucket. I have the same quick attach on my NH TNS75 and share attachments. The TNS75 has the Bobcat type hydralics on the bucket frame which many of the attachments require. Pay attention to how many cfm the attachments use. Bobcats, etc. tend to have much higher flow rates than smaller compacts. My 75 is 16.9gpm and this is at the low end of what I found to be required for the attachments that I am looking at.
/ best attachment for 20"+ rocks #6
I took a look at the video, too, Alf, and now I want you to get one of them diggers and bring it over to my property to try it on my soil. /w3tcompact/icons/smile.gif
Seriously, it looked good in the video, but that was some mighty cooperative dirt it was working in. Of course, you and others here might just have that kind of soil, but it makes me wonder what its real limits are. /w3tcompact/icons/crazy.gif
/ best attachment for 20"+ rocks #7
Because alf, started 2 new threads with the same subject matter (just different title), my post I wrote yesterday is kind of alone in the dark, so I will insert it here as well.
I am ordering a Bobcat 873 today.
I have looked into the digger attachment. It is a very handy tool. Retail prices for it are as follows:
12, 16, and 25" models are $1025
30" is $1100 and at 36" is $1125
I plan on getting a digger, and using it to trench water and electric lines, dig footers, and remove rocks -- I am sure I will find many more uses for it as well.
Dave "Gatorboy" Hoffmann
/ best attachment for 20"+ rocks #8
Rooter bucket rocks
I have the ATI quick attach (http://www.abcgroff.com/ic/ati6.htm#1) on my NH-TC40D (16LA FEL), on which I interchange my 4-in-1 with my Rooter bucket (http://www.kascomfg.com/rooter.htm).
I can't say enough good things about the Rooter bucket. It was about $1000, and does everything Kasco claims, and more.
I use its concentrated force to dig out huge rocks (the Rooter gives great leverage) and pluck out those 1 footers that keep popping up in the lawn each year with the frost. Because of the length of the bucket, you can dig holes 4-5' deep (be careful not to drive into them!). And because the tip is narrow, you don't have to make a 6' scar like you do with the big bucket just to get out a little rock. I have dug out huge rocks that I can't pick up with the FEL but can then push or tow with a chain.
Stumps, you ask? I recently dug out a dozen maple stumps, half of them 2' diameter (chainsaw cut) with root balls almost 8' across (where I severed them) and 3' below grade. Took about 2 hours per big stump. The smaller 4-6" stumps take only a few minutes. Used the angled edge on the Rooter bucket to snap the roots on all sides. Of course, I couldn't pick up the root ball, so I continually "combed" across the underside of the root ball to remove dirt and rocks until I could push the stump out by tipping it over. Very important to have 4' of the stump above ground for leverage when you push! Once tipped over, I would comb down to get the remaining dirt and entwined rocks off (helps to fill the hole in addition to cutting the weight).Yes, this is a lot of back and forth driving (thank you HST) and is a bit tedious. Then I slid them 100 yards through the woods over to my stump pile.
WARNING: Don't try this on a slope! Flat ground only. Also, you really have to be careful that you don't let the heavy root ball tip you over when it comes down. Root balls are VERY heavy.
FYI, I do not have a backhoe and generally have no need for one, so this is my cheap alternative. Yes, a dozer or backhoe would take out the stumps faster, but this way I can do them at my leisure and save some money (don't have much left after buying the TC40D!).
Actually, I have rocky clay soil which gets really hard when dry. However, I think that when the soil is moist, the digger could be used to leverage larger rocks out of the ground and also to dig small holes (say 1 ft deep, 2 ft wide) for transplanting saplings, shrubs, etc. This is most of the digging I need to do. Hey, its got to be better than a shovel. The Bobcat can also run a brush mower (Brushwolf, Ammbusher, etc.). Although these are very expensive mowers relative to a rotary cutter for a tractor ($5000 vs. $1000), I like the compact nature of the skid steer, and I save $6000 on a backhoe. So I'm still $2000 ahead!
Re: Rooter bucket rocks
Thanks a ton, Kent. This is the kind of info I am looking for. I'm still undecided between the tractor and skid steer. The skid steer has agility and size advantage on my woodsy trails. The tractor has advantages for field mowing and would be more stable on uneven terrain. Do you know how low capacity a loader (i.e., how small a tractor) could be used with the Rooter?
Kent, forgot to ask. What kind of rear ballast do you need on your tractor with the Rooter bucket?
/ best attachment for 20"+ rocks #12
Tractor stability
I have 5 acres, 1 of which is "flat". The rest is sloped between 5 and 15 degrees (angle). It is heavily wooded and typical New England rocky.
My dream machine was a 4-wheel drive (perhaps articulated) low-slung tractor like the Holder (
http://www.holdertractor.com/c870h/main-c870h.html) or even the Wilkov-5000 (http://www.wisconsineng.com/index.htm) but there wasn't a dealer anywhere near me, or in the US for that matter! The key is having 4 same-sized wheels. Articulation is a bonus.
I haven't driven a skidsteer, but have never heard from anyone that they are "great in the woods" or on slopes. I suspect not. Don't get your hopes up on anything that is not specifically built for rough terrain or slopes. There are other tractors out there, like Steiner or Ventrac, which may be better on slopes. What you buy should look more like a logging skidder than a farm tractor if you want to handle the woods and hills. Moreover, I have learned the expensive lesson that there is no one tractor that will do everything you want to do.
So, I compromised and bought a traditional tractor, a New Holland TC-40D, thinking it could handle traversing the rocky slopes on my property as long as I followed all the safety recommendations. When I "measured" the slopes before I bought the tractor, they didn't seem that steep. But sitting on the tractor, they are immense and impossible. Sure, it can go up/down the slopes (they aren't mountains), but forget about crossing even the most minor slopes. Just roll a tire over a small rock or into a small divot, carry just a little weight in the FEL, and forget it. All the center of gravity rules are now violated. The problem is not so much slope angle in one direction, but when you combine the cross slope and the down slope, I can very quickly get into spots where I start to feel the upslope wheel(s) starting to unload. Not a good feeling. So I back up slowly and try to find a better way around by inching past that rock/divot. Sure, I can go straight up/down a somewhat steep slope (such as for mowing), but what do you do need to turn around? Unless you have a flat area at either end, you can't do it. Simply impossible with any speed or sense of security. I have approached 15 degrees going straight across a smooth slope, but I was sure I was going to tip over, and got off of it as soon as possible. I am comfortable at 5 degrees as long as there aren't any rocks/divots. But that 5 degrees quickly turns into 25 degrees when that big rear wheel rolls over that rock.
And carrying any type of a load in the FEL DOWN any type of slope is dicey. Even when I use my 900 lb. box blade as a counterweight, this isn't even enough in some cases…the rear wheels like to come off the ground (you have never seen a bucket come down so quickly to get them back down!). Another not-so-fun feeling. I have to dump some weight and ease my way down or back down (not too much fun either).
So I have learned the limitations of a traditional farm tractor! Don't get me wrong. It has done amazing things around here. But some of the projects I envisioned doing before I got the tractor will simply not get done using that machine. And someday, I'll move to a flatter piece of ground, so given that the tractor is a 20 year investment, it will more than pay for itself wherever I live.
/ best attachment for 20"+ rocks #13
Kent,
Very cool tool. I've thought about a backhoe a few times but never very seriously due to the high cost. That rooter looks very interesting. I have many needs to dig trenches a couple feet deep, remove old tree stumps, etc but have successfully found excuses to do other projects to avoid digging by hand. Have come very close to spending hundreds to rent the equipment to do it all over a couple weekends but have trouble parting with that much money and not having any toys in return.
I think that a new item was just added to my list (make that two new items: quick attach bracket and rooter). Now wish I had gotten the quick attach when I bought the tractor...
DaveV
Re: Tractor stability
Thanks again, Kent. I was thinking a Bobcat with steel tracks might be OK in the relatively flat areas. I might be wrong, and I would have no intention of tackling the steeper hills. ASV is another possibility as a tracked machine. By the way, do you think the loader on an Kubota L3010 (1000 lb lift) could handle the Rooter?
/ best attachment for 20"+ rocks #15
Rooter and horsepower
I have 40 HP, and when cutting 4" roots, it takes a half-dozen or so "stabs" to break them a little at a time. If too tough, I move outwards a foot and try again. When doing this, I would slide under the root with the Rooter bucket tip/angled side (it is shaped like a big wedge) until the engine started to overload (RPM starts to drop, get some black smoke), and then back up ASAP before it stalled. Unfortunately, the HST on the TC40 tends to (for lack of a better description) keep "pushing forward" under load even though you have let your foot off the forward pedal, so you really have to be aware of the load and hit the reverse pedal as soon as it starts to bog down. (as you may know, the TC40 has two HST pedals, not the single treadle pedal design like the middle size TC's).
My whole point here is that sure, having a larger tractor would have been nice, and I don't think you would have luck with huge tree balls with anything smaller than 40 HP. I think I reached the limit of its capabilities. But with foot diameter trees or less, no problem with something smaller.
By the way, this past weekend, I used the Rooter bucket to transplant six 8-10' pine trees. Don't know if they'll live or not, but getting the entire root system out was no problem! The center of the root ball ends up resting on the tip of the bucket. I used two guide ropes to secure the tree mid-trunk to the curl arms and then leaned the bucket forward a bit to put tension on the ropes while driving to the new spot. Then just slide the roots down into the new hole. The largest tree, though, had just too much dirt and I couldn't go down the slight incline w/o the rear wheels starting to unload. So I had to break most of the dirt off the root ball. Even with the 900 lb box blade, that extra leverage of the long nose bucket was just too much. When digging out big rocks and stumps, I would just push them around anyway and not try to pick them up (just didn't want to do this to the pine tree root ball I wanted to protect!)
So in addition to HP, the weight of your tractor makes a difference too. Heavier is better. I tried using the Rooter bucket with no rear weight, with the rear blade (450 lbs), and with the box blade (900 lbs). Best results with the box blade both in cutting roots and lifting. Plus the box blade has the least amount of swing, so it felt more solid all around. Plus, I used the box blade running backwards to push dirt back into the hole.
/ best attachment for 20"+ rocks #16
RE: 1000 lift enough?
Don't know! The 16LA loader on the TC40 says 1,800-2,000 lbs. But I think this assumes that much weight on the back to counterweight (which I don't and can never have, really) AND you would also subtract the weight of the bucket (and the weight of the quick-attach unit). So when I have the 4-in-one bucket installed (heavy), the lifting capacity is much less than if I had a standard bucket. The thing about the Rooter bucket is that it is only a couple of hundred pounds (I can roll it around end-to-end by hand), which is lighter than any full-size bucket. But because it can carry less volume than a regular bucket, I would think that this would translate into greater lifting power than what you see with a regular bucket. But it is still very easy to get locked in under a heavy rock or root and have no curl or boom strength left.
You do have several things going for you with the Rooter bucket: greater leverage due to its length (you'll learn how to scoop almost like a backhoe), those teeth, and the fact that you are concentrating all your power on about 8" at the tip (like a needlenose pliers). Oh, one more thing. Because of its length when straight out, I can see the tip looking down the sloping TC40 hood, so I know where I am going to start angling down to dig the hole.
Did I mention that I liked the Rooter bucket? OK, the drawback is that it is useless for backfilling or smoothing. Switch back to the big bucket for that work or use the box blade in reverse.
Geeze, I sound like a Rooter bucket salesman. I'll stop now....
/ best attachment for 20"+ rocks #17
Re: RE: 1000 lift enough?
Kent,
I'm glad you are stopping the talk about the Rooter. I've been salivating about what I could do with the Rooter. Still trying to figure out how I could talk my CFO into releasing some money from our furniture fund in order to get one but don't know if it is worth risking ... /w3tcompact/icons/wink.gif
DaveV
Called Kasco. Rooter is only recommended for 40+ hp on a compact tractor.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
New Holland 499 MoCo (A66408)
New Holland 499...
New/Unused 6ft Quick Attach Brush Cutter (A65579)
New/Unused 6ft...
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
2014 Freightliner M2 106 Water Truck, VIN # 1FVACXDTXEHFU5910 (A65563)
2014 Freightliner...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
