Berry trellis
/ Berry trellis #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Just put up two 25" trellises for blackberries, and black raspberries. Still need to put in a 3rd wire.
Any tips from the pro berry farmers?
/ Berry trellis #2
Looks better then what I have. But what really impresses me is your grass!!!! WOW, it's super thick and green.
/ Berry trellis #3
I have been considering some black and raspberry bushes. Do they put offshoots out on their own once you have the first plant?
/ Berry trellis #4
I have not seen that on my two blackberries, but birds will spread them quite well. YMMV
/ Berry trellis #5
At $15 a bush, I was kinda hoping mother nature would take over! :ROFLMAO:
/ Berry trellis
My girlfriend is from Cleburne TX. I have seen your grass.
Feel free to stop by and jump on the Kubota. I have only mowed it once so far because the ground was too soggy. Already sick of it. LOL
/ Berry trellis
One you have them you won't need to buy them again. I believe they are easy to propagate.
/ Berry trellis #9
I’ve been growing raspberries for about 10 years. I grow the primocane varieties, so they fruit from new canes each year and I cut the old canes to the ground each winter. So I don’t use a trellis; I just let them form bushy rows.
/ Berry trellis
I planted Jewel black raspberries. They fruit on last year's cane.
/ Berry trellis #11
Oh. Those are a bit harder to manage, but my recommendation is to try them without a trellis and see if you need one. You can always hedge trim them if they get unruly. The reason I say those are harder to manage (floricane varieties) is that you need to prune out the old canes, while keeping the new canes at the end of every season, so the pruning is slow and labor intensive. With primocane varieties, you cut everything to the ground in winter and they resprout with new fruiting canes each spring.
/ Berry trellis #12
My experience is that raspberries will propagate quickly and take over any area you don't regularly mow. Blackberries propagate but much slower. I think it's because raspberries fruit on the new canes (so you can cut them all down at the end of the year) but blackberries bear on the 2nd year canes.
My berries are planted next to a chain link fence, so I put some posts 2 feet away from the fence and run wires to contain the canes between them. Works pretty well.
/ Berry trellis #13
Depends on which type of raspberries you have. Floricane varieties fruit on second year canes. Primocane varieties fruit on new canes.
/ Berry trellis #14
@dj1701
FWIW: We set up our trellis system a little differently, with two trellises, one on each side of the bushes. It helps keep the canes up and I think that it makes the berries easier to access. It also makes pruning pretty easy, but not as easy a primocane varieties for sure.
All the best,
Peter
/ Berry trellis
@dj1701
All the best,
Peter
I have no idea what FWIW means.
I set up a two opposing wire system and did not like how it turned out, so I went this route.
/ Berry trellis #17
Mr. Ponytug, what did you use? Was it 3 strand or some kind of mesh fencing?
/ Berry trellis #18
Long ago we tried raspberries. But like the strawberries - the @#$% chipmunks would not leave them alone. They would eat the fruit a couple days before ripe.
One of the trellis's still remains. Quick and easy. Plastic pipe and chicken wire. Behind the farm wagon.
/ Berry trellis #19
I have wild raspberries which shoot and propagate by birds and animals.
The blackberries I planted in chicken wire cages so they just run up the wires.
I only have 2 of the blackberries. If I want raspberries, there are so many I just grab a few, so does my neighbor. They have a tendency to bush out vs. the blackberry.
/ Berry trellis #20
Just some T-posts connected by two strands of smooth fence wire. We did tie the pairs of T-posts together across the trellis. Nothing fancy. We might have used an extra tall post at each end, but I don't recall exactly. Today, I would probably add a stay at each end, but it worked.
All the best,
Peter
PALLET OF RAMPS (A68842)
PALLET OF RAMPS...
OK TRAILER  16 FOOT TRASH TRAILER (A68842)
OK TRAILER 16...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
3145 (A63117)
3145 (A63117)
2023 ASV Posi-Track RT-25 (A64911)
2023 ASV...
