Bercomac SSQA snowblower experiences
/ Bercomac SSQA snowblower experiences #41
To the OP, You mentioned trying to backup on the drive to imitate using a rear blower. Do this the same amount of time that would take to clear the drive. I use a front mount on my drive. No probem. Doing dad's drive with his rear blower, my neck is killing me. About the same size drives. His 1/4 mile one pass up and one pass down. Mine 3/8" of a mile, 2 complete passes up and back. Jon
/ Bercomac SSQA snowblower experiences #42
The Erskine Company has a front mount PTO operated 2 stage blower you can use on your 2305 and any future mule you buy.
This model uses a rear to front Power take off system that is simple to use, install and remove.
Their two stage snow blower uses mounting plates specifically for your tractors frame and
are permanently mounted on it and do not interfere with the front loader mounting frame.
Their 2 stage snow blower and the drive system are designed as one complete frame unit and
the snow blower pins attach with the front mounting systems hydraulic lift system.
The drive shaft for this snow blower is set in the adjustable length frame and the open gear reversing
PTO is designed to be laid over to allow you to drive forward over it to attach it to the rear PTO after
you have connected the two hydraulic hoses to the rear remote to allow you to lift the snow blower
and the snow blower undercarriage enabling you to push the rear PTO mount back to line it up and
connect it to the PTO stub shaft.
The loader arms on your mule would have to come off to use it. If your loader has fold down standing feet all the better.
20 Ton Hydraulic Bottle Jack (A64127)
20 Ton Hydraulic...
Caterpillar 303.5E CR (A64126)
Caterpillar 303.5E...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2002 Jeep Wrangler (A64127)
2002 Jeep Wrangler...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
