Bent Box Blade
/ Bent Box Blade #1
ALBALD1
west virginia
I've got a cheap 5ft boxblade. I think the brand was International. It was just like $350. Used it last summer to level a small area for one of those temporary pools. I just used it to break loose the top 8-10 inches of soil. The bars that go to the side hitches bent outward & raised the blade part off the ground. I guess i wasn't paying enough attention till i noticed it wasn't pushing dirt. the ground was hard, but it never hesitated or spun a tire. I can straighten & brace them, but it don't seem like it should bend that easily. Did I do something wrong or is it just the cheap box?
/ Bent Box Blade #2
<font color="blue"> Did I do something wrong or is it just the cheap box? </font>
Light duty only. Most if not all low end Box blades have to light of steel in them to hold up to any real work.
/ Bent Box Blade #3
I ended up getting a 84" blade. the weight is around 725# ( woods or frontier- same exact specs BB84???). But it cost around 1250$ anything new in steel will run over 1$ a pound. More for better/non-chineese. I dont think I can hurt this one to easily. It will slow/stop the tractor in muddy conditions. But I am traction limited by the R-4 tires. Tires filled. FEL so I should be around 5500-6000# exclusive of the box blade. Get heavier, go norrow if needed but go heavy.
/ Bent Box Blade #4
I have a really heavy duty box blade and bent it. It can happen. I caught mine on a low cut stump. Just have to watch. As said, lighter duty the more easy to bend.
/ Bent Box Blade #5
Anybody care to weigh in as to how heavy a box blade needs to be? What would be the weight of a Light versus Medium versus Heavy weight 5 ft. box blade /forums/images/graemlins/confused.gif
/ Bent Box Blade #6
</font><font color="blue" class="small">( Anybody care to weigh in as to how heavy a box blade needs to be? What would be the weight of a Light versus Medium versus Heavy weight 5 ft. box blade /forums/images/graemlins/confused.gif )</font>
Weights will vary from brand to brand depending on how they are constructed, but Midwest make some nice equipments and they make it in Light, Standard and Heavy Duty.
A typical LIGHT duty blade will use 3/16th thick side plates and something like 10 gauge steel for the rear moldboard. The "a" frame assembly may be simple bar stock.
A typical STANDARD duty box blade will use 1/4" thick side plates, 3/16th inch moldboard. The lower pins will be fully captured clevis type and the "a" frame assembly will be very solid.
A typical HEAVY duty box blade is going to have 3/8ths inch thick side plates, the moldboard will be 3/16th or even 1/4". The "a" frame assembly will be built like a tank. There will likely be several reinforcement points from the front to the rear to keep the box square. Even heavier duty versions will include hydraulic scarifiers and typically those blades are even stouter built.
Here is a photo comparison you may want to look at Box Blade Photo Comparison
/ Bent Box Blade #7
My last BB was 65" and 515lbs rated Med duty and the one I have now is 66", 830lbs and rated for industral use with Hyd scarfiers...it is a beast /forums/images/graemlins/cool.gif
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
F-250 SuperDuty (A63689)
F-250 SuperDuty...
1998 STOLL 35' GOOSENECK LIVESTOCK TRAILER (A63291)
1998 STOLL 35'...
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
2011 FREIGHTLINER M2 112 CNG  6X4 T/A DAYCAB TRACTOR (A59912)
2011 FREIGHTLINER...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
