Bent Axle?
   / Bent Axle? #1
traderfjp
Hendersonville, NC
LS MT240HE
I noticed that one of my back tires is bent in. The other tire looks straight. At first I thought maybe the rim is loose so I jacked that side up and the tire is on properly. Could it be a bent Axle. If so is that covered under warranty? Thanks
   / Bent Axle? #2
if the axle is properly hardened, it would snap, and not bend, I can't imagine a soft axle..
   / Bent Axle?
   / Bent Axle? #4
Does it turn evenly and not wobble?
I guess also, there is Axle as in housing and Axle as in Shaft. Housing should be cast and not bend, shaft should be steel, can bend and the wheel would wobble.
   / Bent Axle? #5
:confused: I'd be interested in your finding when you dig into deeper.
   / Bent Axle? #6
Yes, I would be curious to hear if the wheel wobbles.... a bent rim. To be at that angle, you would think something that was cast, would have broken and not bend.
   / Bent Axle? #7
Measure from the tractor to the rim top and bottom both sides and see what the difference is ....
   / Bent Axle?
I found the problem. Looks like the rim is coming apart. I guess it's welded and not one piece. I'm going to call the dealer tomorrow. Does anyone know if I can bring it to any dealer?rim.JPG
   / Bent Axle? #9
Yes any LS dealer should do warranty work....
   / Bent Axle? #10
More like a bent or improperly installed wheel.
SR
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55301)
2008 Ford F-250...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A55788)
2011 Ram 1500 4x4...
