Bent Axle?
   / Bent Axle?
More like a bent or improperly installed wheel.
DR
Why would u say an improperly installed wheel? The wheel installs one way. Not sure how u could install the wheel wrongly.
   / Bent Axle? #12
Because "some" wheels come with adjustments at the outer rim, I don't know if yours has those adjustments or not. If it does, perhaps there's a problem there?
But you found it, it was more of the bent rim variety...
SR
   / Bent Axle? #13
That might be one of the wheels that is made up of a inner hub, ring, and outer hub, and made to allow different orientations (standard/narrow, flipped/wide, etc). It could simply be coming apart because some of the bolts came loose or fell out. I think if you study it, that would be obvious.
   / Bent Axle? #15
It's also cracked.
That is often a result of loose lug nuts/bolts or loose clamping nuts/bolts. Once the wheel comes loose, driving on it will cause cracking. Too many people find that out the hard way. Super important to check all the wheel lugs and bolts periodically. If the cracking (or any wallowing) is right around one of the bolt holes, you have found your smoking gun.
Can you post a picture of the whole inner rim, so we can see all the bolt holes? And if any fasteners are missing or loose, indicate if those were removed or lost. I would bet there is a high correlation between the cracks and any missing or loose fasteners.
   / Bent Axle? #16
It looks like in the picture that the left side has broken free and the right side is cracked.
   / Bent Axle? #17
Are there suppose to be bolts in the square holes of the inner rim that connect it to tabs on the outer rim or did welds break?
You’re also missing 2 lug bolts that hold the inner rim to the axle.
   / Bent Axle? #19
Yeah, did the OP take the lugs bolts out? I don't think these wheels are adjustable for width, but I'd have to check mine to be sure.
Henderson ain't but a hop, skip and a holler from LS Corporate. I think a road trip might be in order.
   / Bent Axle?
The first thing I did was to remove the tire. Pulled two bolts and saw that the inner part of the rim was damaged. The bolts we're all tight. Just a damaged rim.
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
Year: 2019 Make: Chevrolet Model: Silverado LD Vehicle Type: Pickup Truck Mileage: 83515 Plate: B... (A55852)
Year: 2019 Make...
2018 Land Rover AWD SUV (A55758)
2018 Land Rover...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
1996 Sunflower 1543-38 Folding Disk (A55301)
1996 Sunflower...
11' Container (A53316)
