Bench grinder or angle grinder?
/ Bench grinder or angle grinder? #31
Wet and dry grinder is mostly for sharpening tools like chisels etc.
Get some old steel and clamp it down.
Then practise with your new hand grinder rounding edges, cutting grooves, grinding welds.
These are great tools in the right hands. They can easily get away if you are not holding it right, with the right pressure etc.
I wouldn't want to learn the hard way on a nice new Hydraulic Top Link.
/ Bench grinder or angle grinder? #32
My latest addition is the Wire wheels for the hand grinder.
Both the crimp type and the Cup brush with twisted bristles come for a 5/8" thread. I was about to make an adapter when I found one at my local NAPA auto store. 5/8" to 10mm lets all those accesories work on the smaller grinders.
/ Bench grinder or angle grinder? #33
As others have said, you need both. I've had bench grinders many, many years. My current one looks like this one except I have a 6" model instead of 8". If you use an angle grinder, whether electric or air, you need a good vise to hold the item you're working on. I use a 4" vise myself. Down in the country, I had a Craftsman 4.5" electric, but now all I have is a pneumatic angle die grinder which is great for putting a really fine edge on tools.
/ Bench grinder or angle grinder? #34
canoetrpr said:
I tend to expand my new tools as I run into something I need.
I have no metal working equipment other than a little file. I need to grind down the swivel eye of a hydraulic top link that I recently bought from CCM to make it a few mm smaller.
Long story - it used to JUST fit the OEM top link bracket but I had an extension made to that bracket to move the top link out 4" to accomodate for the Pat's I use. My HTL ended up being a couple inches too short. The new bracket is maybe 1 or 2 mm narrower than the OEM one. The OEM toplink's swivel eye is quite a bit narrower than the one on the HTL I have. Figure I would grind down the HTLs swivel eye.
I see a decent 4.5" angle grinder on sale with disks for cutting and grinding but I imagine that since I can bring the top link to a grinder I could also use a bench grinder (I have neither).
If you were going to buy one - for this and that around a tractor - which would you start with?
Angle grinder if you cannot have both.
Paul
/ Bench grinder or angle grinder? #35
I have a 9" Milwaukee, a 4 1/2" Dewalt and a $20 special 4 1/2" HF angle grinders. Also a Milwaukee electric die grinder, an 8" Ryobi pedestal mounted bench grinder, and a 6" HF bench grinder (forget that one, Ryobi makes a much better 6" for $10 more!). I often use one of my 21" x 3" belt sanders for sharpening and dressing. Even though I assume they were intended for wood, they work great on steel.
IMHO the 4 1/2 angle grinder is by far the most versatile. Cuts/grinds steel, ceramic tile, bricks, rock, concrete, smooths wood, removes rust, sharpens... Never found a use for a Dremel. Had one, lost it, no remorse. The 1/8" burrs are just too small and the torque isn't there. I use the Milwaukee die grinder with 1/4 " shank cutters or with a 1/8"collet reducer if I really need something small. It'll also spin a 3" cutting disc at 25,000 revs and really do some work.
I only recently bought a couple of the Harbor Freight tools. The 4 1/2 HF Chicago Electric angle grinder has been fine. I've actually used it more lately than the Dewalt simply because if I'm going to "let the smoke out of one", I'd rather it be the $20 one. I've been doing some pretty heavy work with 'em lately. The $29 HF Central Machinery 6" bench grinder is useless. It has so little starting torque it won't turn a wire wheel. I can spin the thing with my finger but the motor can't pull it at all. Also the motor diameter is as large as the wheel so it's in the way of everything I try to grind.
Let me throw out another silly question so that when one comes on sale I can pick it up...
I see 6" and 8" bench grinders advertised. I was guessing that I would just go with an 8. 6" is a bit cheaper. Any reason I should go with one and not the other?
/ Bench grinder or angle grinder? #37
3RRL said:
Be very careful with that though, like all the grinders mentioned here. I saw one of my guys lose a thumb in one second. He was grinding a flat wear plate and got it sucked in between the wheel and the table. His thumb followed and there was nothing left to put back on.
I'll never forget that since I was standing right next to him when it happened.
When I was in high school auto shop class, one of the druggie idiot students used the shop's bench grinder to trim his fingernails. I just shook my head when I was watching him do this. He never got hurt, so I guess in his case the old saying about God protecting fools and drunks applied.
/ Bench grinder or angle grinder? #38
I like the larger wheels as their motors have more torque, and they put less of a curve on the surface you are grinding.
/ Bench grinder or angle grinder? #39
I like the 8"... I have a craftsman, they put stuff on sale/have specials around Christmas time so that痴 when I picked mine up.
Oh yeah.... _always_ wear gloves with the angle grinder... those things just love skin. I also prefer a faceshield to glasses, especially when using a wire brush/wheel.
/ Bench grinder or angle grinder? #40
Yea!! I hate picking out those wires that have embedded like needles. It is bad enough in the Levis, but in the face that would be painful. The only thing worse is a die grinder and a carbide cutter--those really make small little darts!!
Mike
2001 INTERNATIONAL 4700 BOX TRUCK (A59906)
2001 INTERNATIONAL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2007 Chevrolet W5500 20FT Dovetail Flatbed Truck (A59230)
2007 Chevrolet...
