Belt Conditioner?
/ Belt Conditioner? #1
ammodram
Western Pennsylvania
Kubota L245DT
Anybody use spray-on belt conditioner like they sell at auto parts stores on fan belts and so forth on their tractor?
Just wondering if it helps, hurts, or does nothing. I thought about using it on the belts on my older Kubota, since they don't seem to be in bad shape, but are pretty old.
-Matt
/ Belt Conditioner? #2
Don't use anything if they aren't causing a problem... it's not like hair conditioner where it helps make it last longer...
if you have to use something.. get some white candle /wax and hold it to the belt.. ( be carefull)
soundguy
/ Belt Conditioner?
Hmmm. I didn't use much conditioner as a kid. Maybe that's why my hair didn't last past my early 20's. :D
Thanks for the info. Belts aren't making any noises, I just wondered if it would prolong the life of the belt. Apparently not.
-Matt
/ Belt Conditioner? #4
-Matt
Anything that remains like grease or oil will collect dust, and most likley shorten the belt life. Does the belt or tractor manufacturer reccomend the stuff? I have never heard of any who have, but I have never looked too hard either.
I personally have never had any use for the stuff. It might mask a problem for a little while, but that problem will eventually return.
My .02
/ Belt Conditioner? #5
As i mentioned.. the only belt dressing I use is parafin wax... If you ask for belt dressing at a CAT counter, you get a tube of yellowish parafin that has a spiral paper peel lable on it.. pell off some paper and apply the wax to the running belt.. etc.
soundguy
/ Belt Conditioner? #6
Whatever you do, please be careful. I have a friend who was dressing a belt on a running engine and lost a finger by getting it caught in a pulley.
/ Belt Conditioner? #7
I haven't used any on my tractor, but on large air handling units I've used WD 40 or LPS lubricant to prolong belt life. I did a little experiment with 2 large air handlers for a year belts with lube never cracked or showed signs of wear. The one with no lube needed belts twice. Same environment and run time. A friend of mine was an industrial mechanic he showed me that trick.
Solo
/ Belt Conditioner? #8
I'd be surprised that wd-40 hung around long enough to do anything meaningfull...
soundguy
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
JOHN DEERE 6330 TRACTOR (A65057)
JOHN DEERE 6330...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
2015 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2015 (INOPERABLE)...
1993 Brenner 307 SS Insulated T/A Chemical Tanker Trailer (A68183)
1993 Brenner 307...
