Belarus Tractor Problem
   / Belarus Tractor Problem #1
Joer205
Duluth, MN 55811
I've got a Belarus tractor 500 and all of a sudden the oil pressure dropped to 0 and it started knocking. Shut it off and towed it to the barn and dropped the pan. Oil pump is ok and then thought it might be a rear main. Pulled apart and main looks good. Took the centrifical oil filter apart and checked and cleaned that but that didn't look like it was the problem either. Anyone have a similiar problem or does anyone know what the problem might be. Thanks for anything, Joe
   / Belarus Tractor Problem #2
On my jeep I first check the oil gauge. The one inside is electrical - I plug in temporarily a mechanical, directly in the block and make sure it is not just ther sender or short circuit.
   / Belarus Tractor Problem #3
The gauge could be bad but that wouldn't explain the knocking .
   / Belarus Tractor Problem #4
Check all the bearings sounds like one mau have stacked or spun. I had one go like that in my old JD scraper at work.
Thanks alot. Have checked the rear main but not the rest of them but will do now. Thanks again, Joe
   / Belarus Tractor Problem #6
you say the oil pump is ok but does it turn with the engine............Larry
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A53473)
2023 Maxx-D TDX...
Kubota RTV500 (A47384)
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
HarbinGer V3 Plus...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
