Belarus Tractor Problem
   / Belarus Tractor Problem #1
Joer205
Duluth, MN 55811
I've got a Belarus tractor 500 and all of a sudden the oil pressure dropped to 0 and it started knocking. Shut it off and towed it to the barn and dropped the pan. Oil pump is ok and then thought it might be a rear main. Pulled apart and main looks good. Took the centrifical oil filter apart and checked and cleaned that but that didn't look like it was the problem either. Anyone have a similiar problem or does anyone know what the problem might be. Thanks for anything, Joe
   / Belarus Tractor Problem #2
On my jeep I first check the oil gauge. The one inside is electrical - I plug in temporarily a mechanical, directly in the block and make sure it is not just ther sender or short circuit.
   / Belarus Tractor Problem #3
The gauge could be bad but that wouldn't explain the knocking .
   / Belarus Tractor Problem #4
Check all the bearings sounds like one mau have stacked or spun. I had one go like that in my old JD scraper at work.
Thanks alot. Have checked the rear main but not the rest of them but will do now. Thanks again, Joe
   / Belarus Tractor Problem #6
you say the oil pump is ok but does it turn with the engine............Larry
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
Lockwood 480 Pecan Harvester (A53473)
Lockwood 480 Pecan...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
