Before & After
/ Before & After #1
IrTxRx
Central Texas
Power Trac 1430
I wanted to start a thread that shows what our projects looked like before we started and the end results after application of our PT's and their various attachments. So many times everyone on the board is so excited to get on their tractor that we only get AFTER pictures. This makes it a little difficult to get visual information for how much work our tractors can do.
Case in point, my driveway used to look like a creekbed and is now smooth. The amount of work that my new baby did is impressive to me, but I forgot to take the creekbed picture... oops.
I went out and took a bunch of pictures of areas that I expect to be working on in the near future. That way, I will have a file to refer to when I excitedly get on the tractor and take the after picture.
/ Before & After
Before --
Record rainfall in Central Texas let native bluestem grasses grow 6ft high
/ Before & After
After --
2.5 hours later, burp the baby, and finish the job.
4 acres of 6 foot tall prairie grass, 1 broken blade after 30 minutes of mowing, 35 chewed up old cedar stumps because the mower mows WAY to low for a brush cutter. Still, I LOVE MY MUT!!!
My grass seemed to mow a little better when it was just barely damp, FWIW
Also, My front casters are FILLED from the factory. But I don't think my grease zerks are going to last long...
/ Before & After #4
Greetings,
Would it be in bad taste to show a before and after of the PT-429 before and after I use the CT322 for it's first application?
Love,
Steve
/ Before & After
scarg said:
Greetings,
Love,
Steve
Perfect...let 'er rip
Edit - oops, just assumed that you were doing another awesome mod on the 429 before I read your other post...But, yeah, I think it is part of the story. I would guess only a hundred or so PT posters and five have gone back to regular CUTs that I can think of off the top of my head.
/ Before & After
Before...nope, forgot to take pic
After...nope, remebered to take pic before I was through
BRAFTER --
removed a shrub that grows like crasy and makes it hard to mow no matter how much I prune it back every year. It is about 6 inches in diameter with medium sized root ball. Lackender hoe with grapply, no problem and bye-bye shrub
/ Before & After
Before -
big hill of kaliche (caliche) road base and I need material for my drive
/ Before & After
Before (road base hill, con't) --
I love my PT, but one of its biggest weaknesses is brute force (or lack thereof) so what to do... Minihoe, possible... teeth on grapple, probly not... Potato digger, sounds good... but wait, the roar of the 2cylinder engine the whine of the PTO and the glint of sunshine off 24 carbide tipped teeth, enter the wheel trencher
Man I love yhis attachment. It is truly impossible to appreciate this machine unless you have tried to dig in our central texas soil (e.g. clay/rock).
/ Before & After
After (road base) --
Two hours of tractor time later and the PT has a new parking space. The deminsions are (4' X 8' X 14') / 2 which is 224cubic feet which is pretty close to a 10 yard dump truck of material (PT already saved me $150, yeehaw).
After the initial cutting fun with the wheel trencher, I also used the lackender hoe. However, i found that the best tool was the potato digger. Mainly it was best because of speed. Drop the LM bucket, pick up he potato digger and rip the hill a little, stab the digger in the ground and un hook, back to the bucket. Unpowered implement to unpowered implement wins the day (but turning the wheel trencher up and driving into the hillside was still the most fun!!!).
BTW -- check out the awesome parking job (if I do say so myself)!!!
/ Before & After
Before (my road is a son-of-a-ditch)
Our 1/4 mile drive has not had any maintenance since it was cut in 1992. I forgot to take pics of the drive, but basically it looked like a creekbed, because it had become the ditch. I got all the potholes filled in, now I just need to get new ditches cut before (if) it rains again.
/ Before & After #12
Moved approx 2500 lbs of travertine and slate using a trailer. Tile man coming tomorrow....was going to hook-up to the truck but hate backing and lining up with the hitch. Put hitch in the adapter plate and voila'...
Was very easy to hook-up and move around. The trailer was very steerable.
Trailer driving PT style is a hoot! :D What with the "double articulation" of the PT and trailer.
Sorry, no "after" pick. It was just an empty trailer....:D If the PT would have fit through a "36 wide door the job would have been much easier.... just say'n.
/ Before & After
We want to rip up all our various floor coverings and put refinished, stained concrete in its place. I MAY take off the sliding glass doors and do some INDOOR TRACTORING!!! (CFO still hasn't signed off on the idea though) If I do, I will definitely post before, during and after pics.
Full speed ahead and Dang the carbon monoxide!!!
/ Before & After #15
You know, that sounds funny and all, but at my employer, we have had to remove carpet that was glued down to concrete many times. The guys take two 2x4 and sandwich the edge of the carpet between them and bolt them together with carriage bolts and wing nuts. Then they attach pull straps to each end of the lumber and make a Y connection to an electric powered skid mover (a mini forklift) and back up. It pulls the carpet off nice and evenly. :)
/ Before & After #16
I've seen stained concrete with different patterns....NICE! and durable.
A few well positioned throw rugs and comfy slippers and you're good to go!
/ Before & After #17
Said house building continues....
Builder said needed two retaining wall footers dug on each side of the house. 18"D x 15"W x 10ft long. Since we're doing cost "plus" he said a bucket hoe is $100 for the call and $75hr or about 175 total. I said no problem....I'll handle that...you handle the footers/etc.
Here's a before and after....about 15 min work per side. A big bucket hoe would have taken more time to set up than to dig the small trench..:eek:
But hey....I had fun and saved a few bucks.
Hard to show the scale of the trench in the photos. The wide angle shows it best! Would have taken me hours and advils to do it with a shovel.
I have this idea about placing a moat around three sides of the house but SWMBO says no-way! :rolleyes:
Mini Skid Steer (A60352)
Mini Skid Steer...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
8in Channel Tooth Bucket Mini Excavator Attachment (A61572)
8in Channel Tooth...
