Beacon on roof?
/ Beacon on roof? #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Kubota doesnt seem to offer a roof mount beacon option for M series tractors.
Suction cup doesnt give me confidence.
I thought about gluing a piece of galvanized metal to the roof and buying a magnetic base beacon.
Anyone else know of a mounting system or better way?
I assume coiled cord just gets plugged into cig lighter socket, but would like to have factory kubota lighted rocker switch in one of the blank spaces.
/ Beacon on roof? #2
for my kioti i made a simple angle iron bracket that fit on the bolts that hold the cab roof on. then i added a standard 3 wire trailer disconnect plug and ran it down to an aftermarket lighted set of rocker switches. The Whelen flashing light i bought required 2 switches.
A similar thing should work for any type of cabbed tractor. i too shied away from suction cup. I made line so it can be easily removed from bracket for the summer. parts 1.jpglight and bracket.jpgbracket finish 1.jpgmounted 1.jpgrunning 1.jpgswitches 1.jpg
/ Beacon on roof? #3
I used a piece of galvanized fastened to the roof with silicone calk on our BX2660. Works well to hold a magnetic beacon on the roof (as long as you dont drive under a branch).
Aaron Z
/ Beacon on roof? #4
yek.. rtv caulk makes a good bond that CAN be removed without damage to the panel....
/ Beacon on roof? #5
I've fabricated a coupe of roof bars for my top light. I guess its not considered a beacon but one could be attached the same way. One I built for the Kubota 4240 and another for the Kubota 5740. It is bolted to the existing bolts on the cab ans my wiring is ran down inside the cab. Works well for me.
/ Beacon on roof?
Where are you getting your lighted rocker witches from on line?
/ Beacon on roof? #7
beacon.. I thought it said bacon this morning and got hungry.. :)
/ Beacon on roof? #9
now.. the urethane Windshield stuff is a bit extreme :) you may remove paint and fiberglass trying to get that stuff off. :)
