BCS Engine Swap
/ BCS Engine Swap #1
kdk1025
Long Grove
Case 255
Has anyone swapped a Honda GX390 for a Chinese copy? Will they bolt up?
/ BCS Engine Swap #2
Yes, the bolt pattern should be the same.
Which copy are you looking at, and what is wrong with your 390?
/ BCS Engine Swap #3
It should the chinese engines are just clones, Make sure the shaft size is correct
/ BCS Engine Swap #5
Also curious what happened to the Honda GX. I did not know they could ever die unless they were run without oil or some such fate.
/ BCS Engine Swap #6
I made the swap with an 8hp Harbor Freight engine this past summer on a BCS 720. It bolt up went fine. My problem was getting the cone clutch off the old engine shaft. And the new engine works very well. Good luck with your swap.
/ BCS Engine Swap #7
They can die, believe me. Had one on my rear tine tiller and it tossed a rod after about 10 hours. I got no satisfaction from American Honda nor the servicing dealer locally. It now has a Predator motor on it. Been 3 years, no issues. I landfilled it (after I drained what oil was left in it), poured it out through the hole in the block.
Never again
2019 K&K Equipment Trailer, VIN # 1K9PE2029KA175459 (A65563)
2019 K&K Equipment...
Landhero Rigging / Binding Chain / Suspension Equipment (A66408)
Landhero Rigging /...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
John Deere 2840 Tractor (A64047)
John Deere 2840...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
