BCS Engine Swap
/ BCS Engine Swap #1
kdk1025
Long Grove
Case 255
Has anyone swapped a Honda GX390 for a Chinese copy? Will they bolt up?
/ BCS Engine Swap #2
Yes, the bolt pattern should be the same.
Which copy are you looking at, and what is wrong with your 390?
/ BCS Engine Swap #3
It should the chinese engines are just clones, Make sure the shaft size is correct
/ BCS Engine Swap #5
Also curious what happened to the Honda GX. I did not know they could ever die unless they were run without oil or some such fate.
/ BCS Engine Swap #6
I made the swap with an 8hp Harbor Freight engine this past summer on a BCS 720. It bolt up went fine. My problem was getting the cone clutch off the old engine shaft. And the new engine works very well. Good luck with your swap.
/ BCS Engine Swap #7
They can die, believe me. Had one on my rear tine tiller and it tossed a rod after about 10 hours. I got no satisfaction from American Honda nor the servicing dealer locally. It now has a Predator motor on it. Been 3 years, no issues. I landfilled it (after I drained what oil was left in it), poured it out through the hole in the block.
Never again
Woods Rotary Cutter (A63116)
Woods Rotary...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A62131)
UNUSED PAIR OF 76"...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
