BCS 852 Leaker
/ BCS 852 Leaker #1
PhilG327
La Farge, WI
BCS 852
My 852 has the 13hp Honda engine and is about 10 years old now. Last year, I noticed small puddles under the transmission/engine junction but in my usual pattern I ignored it. The puddles are getting larger this year, especially after a good workout with the brush mower (like yesterday around my grape vines). I have only had to add small quantities of oil from time to time to top it off, but it probably is time to fix it once and for all before switching to the snow blower attachment for winter. There appears to be 3 separate places where the engine, adapters and transmission meet and any one of those could be the culprit. Any suggestions where to begin to find the leak ? I don't want to tear the whole thing down unless I have to. Even worse would be to take it to a local shop and pay them to tear the whole thing down. Advice is welcome !
/ BCS 852 Leaker #2
Are you suggesting the engine crankshaft is leaking or the input shaft on the trans? I don't recall a seal on the outside of the engine housing where the crank comes out. I've seen the trans input shaft leak gear oil before. Smell it for the typical acrid smell of 90w gear oil.
Tom
/ BCS 852 Leaker #3
I've had the Honda GX390 leak oil at the filler cap. Pretty sure this was due to filling the oil all the way to the brim (as your supposed to on this motor) and then when the oil warms up after use and expands it seeps out at the filler cap. This leak tends to run down the engine and can look like it is coming from the area where the engine and transmission meet, but in actuality it's not.
A little coming out the filler cap I did not consider serious. Not saying this is your issue, but might be worth checking into.
/ BCS 852 Leaker #4
I have an 850 that was leaking it sounds like from the same area as you mention. It smelled like 90w oil to me, so I pulled the engine off and it appears to be leaking from the seal on the main drive shaft of the tractor. I am in the process of replacing that seal now. We shall see how it goes.
/ BCS 852 Leaker
Ran the BCS with the brush mower for about an hour today, cutting the weeds and etc. along the road. Parked it in a spot in the barn with no previous drips from any machine, and after 2 hours of waiting I found not a drop. Both engine and trans appear to have plenty of fluid (as far as I can tell). It will be interesting to see if it starts to leak after it sits all nite or not. Suggestions ? Ignore it ?
/ BCS 852 Leaker #6
Phil, how did you end up with this leak?
/ BCS 852 Leaker
As it happens, it still leaks - a little now. After sitting almost all winter (no big snow for the snowblower attachment), I discovered a puddle under it in early February. Shop found a loose bolt and changed the oil for me, but after using the brush mower attachment for about 1/2 an hour last week I found another small puddle under it. I may have no choice but to try another BCS shop.
/ BCS 852 Leaker #8
Hi! I think oil is come from transmission input shaft. I learn with time. Do not overfill transmission oil. Do not park or work for long time with engine very down. Oil go front and leak. Park engine with transmission at level or rear down. So less trouble for me now.
Good luck! Oldmech
/ BCS 852 Leaker
Thank you for the advice. My 852 always sits with the front of the engine down with all my attachments (brush hog, sickle mower and snow blower). I'll put a couple of 2x4's under the front and see if that helps. Thanks again.
/ BCS 852 Leaker
Son of a gun ! Tilting the mower seems to have stopped the leak - no puddles under it today. Thank you very much for the advice, oldmech.
/ BCS 852 Leaker
Rats ! I thought this was all resolved, but just discovered yesterday that there is a good sized puddle under my BCS again. Long, long ago in a previous life, I drove very small Italian cars at very high speed and had one that leaked. After many tear downs, we finally added some sort of dye to the oil before we could find the slow leak on a slightly warped valve cover. Anyone familiar with this particular trick ?
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2017 Ford F-150 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
2007 Volvo C70 Sedan (A61569)
2007 Volvo C70...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
