BCS 850 new engine
/ BCS 850 new engine #1
farmersmall
bend, oregon
ford,pasquali,allis G, bcs, goldoni, ferrari
I have a BCS 850 that came without the Briggs v twin engine. Will the adaptor work on a replacement engine like the honda. Apperently the engine shaft for the clutch was 1 1/4" and so doesn't fit any of the replacement engines available from earthtools. I want to put a new motor on this tractor and if I need to a new clutch along with new cables and make it like new. Any help would be appreciated. Thanks
Jim
/ BCS 850 new engine #2
Are you sure about the clutch? I think the only clutch over an inch was the 14 hp Kohler on the 745, 945, 946 models.
The adapter will definitely work for most of the engines available.
/ BCS 850 new engine #3
I replaced the 14 hp B&S with a Honda, from Earth tools. sent my clutch to them, they installed it and shipped me the complete motor assembly. Made the swap very simple. If I were you, I would call Joel and ask, can't find a nicer bunch to work with.
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 2840 Tractor (A64047)
John Deere 2840...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
