BCS 755 engine replacement
/ BCS 755 engine replacement #1
devkrev
Vermont
BCS 739
Hey all,
I'm currently in the market for a used BCS tractor for use around my home.
There is a craigslist posting for a BCS 755 with some attachments for $2000
Bcs tractor 755 with attachments
Anyway, the tractor doesn't currently have an engine. From what I have read, the 755 is actually a Grillo machine. I was wondering about the difficulty and price of procuring a new engine for the tractor, and any pitfalls or issues that may be associated with it.
Thanks!
Dev
/ BCS 755 engine replacement #2
That's not a 755. He read the numbers stamped in the transmission casing and wrongly assumed it was a 755. Pretty sure it's a 735, but his pictures suck, so I could be wrong. Missing the engine, that's about double what I feel it's worth. If he has the clutch and adapter off the engine, you could mount a GX390 for under $700. If he doesn't, figure another $180.
Huh, well it works out for me because the 755 was a little more machine than I really was looking for. I sent the guy an email, I guess we will see how things pan out. I asked for more pictures too.
Edit: It seems like he is just going off the serial number, is there an online resource to show that his serial number is the 735?
/ BCS 755 engine replacement #4
No, the serial numbers were never kept track of, at least in the US. The only way to tell the models apart is to look at features. That one has the steering column of a 715/725/735, and it looks like it has enough cables to have brakes. a 755 will have a nearly 90 degree curved round pipe for a steering column, a larger transmission, and larger tires. google bcs 755 to see what I mean.
I was just wondering about official documentation just to show the seller, with craigslist being craigslist.
Yeah, I totally know what you mean about the differences. It's fairly close by so going and seeing it in person will get me a better idea, I'll take some pictures myself to share.
Thank you for your help though!
/ BCS 755 engine replacement #6
People being people, he's either going to believe you, or he's not. Frankly, it being a 735 makes it slightly more desirable (more nimble, more attachments available), so he has reason to believe you. BCS Spa didn't import very many 755s.
$2000 is a price to pay for a machine ready to work. You're gonna have $900 in an engine, clutch, adapter, and shipping. That sickle mower ate a rock (LH sections are busted up, guards are turned all the way to the back of the bar), and it's missing the cover. The 30" combo mower is a POS that will wreck your PTO when you hit a hard object like a stump or rock. The snowblower also ate a rock (bent up propeller). The tiller looks good, but I'd suspect ti, seeing the damage to the other attachments. He oughtta be asking $600 and be happy to get it.
I've long said, Grillo and BCS machines can only be damaged by abuse or neglect. This machine is thrashed.
Did you see the 737 in Underhill? I think he's a little high, but it is likely a better rig than this one.
The 737 was already sold the seller just didn't delist it.
/ BCS 755 engine replacement #8
Did you look at the model chart on Earth tools? There might be enough there to help distinguish it. http://earthtoolsbcs.com/static/pdf/BCS_Model_Chart1.pdf
Awesome thanks, it looks like the 735 has 12mm studs for the pto and the and the 755 has 14.
It also seems like the 735 has 5 x 10 tires and the 755 has 6 x 12.5
/ BCS 755 engine replacement #12
Definitely a 735. The T bar on the RH handlebar in front of the throttle. It's broken, of course. Did he still have the engine and clutch? Did you make him an offer?
He had neither the engine or the clutch. He seemed fairly firm on his price. The engine blew because he ran it without any oil.
I didn't make an offer, I'll probably end up passing on it.
/ BCS 755 engine replacement #14
It has brakes and a differential lever on the right handle bar. Those, along with the splined PTO fit the 735 features.
(ooops, just saw this was already determined)
Ran it without any oil? Ouch. That tells you anything you wanted to know about maintenance and care. Pass.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Informational Lot - Financing (A63688)
Informational Lot...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
