Bcs 740 powersafe first run-in
   / Bcs 740 powersafe first run-in #21
Thanks for keeping this thread going. Very interesting.
   / Bcs 740 powersafe first run-in #22
Hi again ;)
Recently I passed 400 working hours on my BCS 740, which meant that it was again time for a bit of maintenance. According to the BCS manual, the transmission oil, including the filter, should be changed every 100 hours, and the magnetic oil cap should be cleaned as well.
The Honda owner’s manual also recommends an engine oil change every 100 hours, as well as cleaning the air filter.
I always remove the engine protection bar for better access to the 2 engine drain plugs, and while the oil drains, I remove the recoil starter and cleans it and the area behind it from debris.
This is how the magnetic oil cap looked this time:
Compared to the photo in post #20, there are perhaps slightly less metal particles this time, but I’m still puzzled that it is this much :unsure:
Best regards
Jens
   / Bcs 740 powersafe first run-in #23
Jens, I changed the gear oil on my 739 last fall. I never did get an hour meter so don't know how many hours. But I think I remember changing it and the filter not too long after I bought the thing and thought it was probably time again. I had an empty filter box on the shelf that I kept for the part number and thought there was a filter in it so I didn't end up changing the filter since the box was empty.
Anyway, I was surprised to see a decent size chunk of what appeared to be the end of a gear tooth stuck to the magnet. Along with some fine splinters like you have there. Maybe a 5mm diameter piece of metal. Not round at all though really. I don't know where that came from other than me grinding some gears too hard. I think I do remember accidentally reversing under load. And I tried a couple times to "feather" in the pto engagement with the clutch.
If there's any metal in the hydraulic clutch pack, that could be where the fine stuff is coming from. That clutch must be under an unbelievable load instantly engaging and disengaging with the brake and all. I'm surprised it can even handle that abuse. Other than that, I think what you're seeing is perfectly normal. Every magnetic plug I take out of every component on every piece of equipment I work on always has fine metal particles on it. It's simply normal wear of machinery.
A BCS is completely rebuildable. All the parts are available AFAIK. If something catastrophic happens it can be fixed. No problem. Come to think of it I can't remember ever hearing about a BCS ever failing except for the motor. And the cone clutch seizing up. Have you ever heard of one braking?
Despite the piece of metal, mine still runs and operates as it should. I use mine all the time, some of the best money I ever spent. I couldn't get by without it. It will be interesting to see if any of us can wear one of these things out. Looks like prices have practically doubled due to inflation.
   / Bcs 740 powersafe first run-in #24
Hi Nibbana ;)
You are probably right, that the fine splinters on the magnet are what one has to accept as part of the normal wear of the tractor :unsure:
At the first oil change I wasn’t that surprised, as I took the material on the magnet as part of the normal run-in procedure, but that it is still this much, surprises me a little - but OK. I can’t help to think if there are also some metal particles in the oil filter? Like you, I try to be as gentle to the gearbox as possible, but due to the simple sliding mesh gearbox that our tractors have, it takes quite a lot of experience and skill to avoid grinding the gears and PTO once in a while :cry:
That you have found a 5 mm piece of metal on the magnet doesn’t sound right to me. I would also guess that it is the tip of a gear wheel, either from the gearbox or from the PTO-mechanism.
One of the disadvantages of this type of gearbox, is that it is almost impossible to engage or change gear while moving. As my tractor was new, I did try to practice changing gear while on the move, but it takes a lot of skill and practice, so I decided to do all gear changes, all engagements of the PTO, and all changes of direction from a standstill. This hasn’t eliminated the occasional „grinding“, but it has reduced it a lot.
Sadly I have not been able to find anyone in my area that has a BCS tractor, so I only have the information in this great forum to compare with. These tractors are very well build, and to brake one will take a lot of malicious abuse, I imagine. If used as intended, your grandchildren will also be able to enjoy your tractor.
Looking at my BCS 740 sitting in a dry and warm garage after 13 years and 400 working hours, it still looks and runs like new. I feel confident that it will easily outlive me, and probably the next few owners as well :ROFLMAO:
Best regards
Jens
   / Bcs 740 powersafe first run-in #25
Jens,
I do think that piece of metal I found was probably the corner of a gear tooth. Thinking about it, when I first got the tractor I didn't know how to properly engage the pto and would sometimes try to "feather" it in with the clutch. (Have since learned the correct way from Earthtools videos.) You just can't "feather" these hydraulic clutches. And a couple/few times it did go in hard. Another time I was mowing an all too steep slope next to the pond with the sickle bar. I was going down toward the water and the thing started to get away from me. Had to keep my footing pretty square just to keep me and the machine from going head over heels down the slope and into the water. Well I sort of lost my footing and started to stumble and temporarily losing my presence of mind I guess I just instinctively grabbed for the reversing lever and shifted from forward to reverse without the clutch. Luckily the engine rpm was pretty low but it did hammer those gears pretty good. That one could have chipped a tooth for sure. I've stalled the whole machine instantly a few times from getting a rock in the rotary plow. Maybe 1/2 to 3/4 throttle those times. Didn't seem to phase it and started right back up.
They do seem to take an insane amount of abuse without complaining. I'm always working on my Troy-Bilt snowblower and Cub Cadet lawn tractor just to keep them working reasonably well. Not to mention the 2 stroke toys. But that BCS just keeps on doing it's job with nothing but a tank of fuel.
I think I got mine in 2014 so 10 years old now. I'm a lot easier on it now that I've learned how to use it properly. Back then BCS didn't have any good videos and it took me a while to discover EarthTools website and videos. And this great forum. The BCS manuals I got were next to worthless as they didn't even include one for my tractor. The dealer gave me a stack of manuals about 3 inches high that covered just about everything except my tractor. And even if you have the right one those manuals aren't too helpful. The Honda engine manual was pretty good though.
I guess the clutch could wear out. BCS has an instruction sheet somewhere on how to replace that. I remember there's a left hand thread in there somewhere. I've broke my parking brake lever twice from snapping it back off rather than releasing it gently. Lucking it's cast aluminum so I just welded it to repair.
I don't know anyone personally that owns one either. But I know they're out there because I occasionally see BCS equipment on craigslist. Now that I have my duals I'm pretty much set up to do what I want. I do want to get a cultivator working for me. I modified one to pull behind the tractor but haven't tried it yet. This is it. Brinly-Hardy 18-40 in. Sleeve Hitch Adjustable Tow-Behind Cultivator CC-55BH - The Home Depot
Nibbana
   / Bcs 740 powersafe first run-in #26
... I do want to get a cultivator working for me. I modified one to pull behind the tractor but haven't tried it yet. This is it. Brinly-Hardy 18-40 in. Sleeve Hitch Adjustable Tow-Behind Cultivator CC-55BH - The Home Depot
Nibbana
I have a similar cultivator except mine has the tines attached via force fit wedges.
I pull it with my Steiner 420 with a cat 0 hitch.
I use a Aldo Biagioli cultivator with my Grillo 107d. It works great. I do have a small garden, maybe 1,000 sq feet.
   / Bcs 740 powersafe first run-in #27
Joecoin,
Do you have a link for the Aldo Biagioli cultivator? Where did you get it?
I have about 2000 square foot garden and need some power cultivation.
Nibbana
   / Bcs 740 powersafe first run-in #28
I got it from Earth Tools.
   / Bcs 740 powersafe first run-in #29
Hi ;)
As I wrote in post #18 in the following thread recently, I have been blessed with good luck for most of the 13 years that I have had my BCS 740:
Zanon ZRF 1000 drum mower
I have only had minor issues like a flat tire or a broken starter rope - that is until October 30th, when the above mentioned damage happened to my Zanon drum mower :cry:
Only 5 days later bad luck struck again, this time hitting the tractor itself. At the end of a job with the drum mower, the handlebars felt „spongy“, especially in the vertical direction. As I had parked the tractor on the trailer, and removed the blue plastic bit that covers the handlebar assembly, I saw the following:
The left photo shows the left hand side of the handlebar assembly where it swivels around the vertical post. The right photo shows the right hand side.
I am of course aware that this is a part of the handlebar assembly that has to cope with quite a lot of stress, especially when working with heavy implements like the flail mower or the drum mower. Still, I was a bit surprised to see this.
This topic was mentioned more than 4 years ago in the „Berta flail mower“ thread, where our member „ppea“ expressed his concerns regarding the risk of braking the handlebars when working with heavy implements. I have had similar concerns over the years, especially with the flail mower and the drum mower, as they are quite heavy, weighing 92 kg/203 lbs and 80 kg/176 lbs respectively. Pressing hard on the handlebars to get these heavy implements off the ground, of course puts a lot of stress on the lower part of the handlebar assembly where it meets the vertical post. Up till now I thought it was up to the job, but it wasn’t anymore :cry:
As with the drum mower recently, my neighbor had a look, and with his lifelong experience working in a machine shop, he had a to me surprising comment concerning the welding on the right hand side: „It’s not the handlebar assembly that has broken, it’s the welding!“ I’m no expert on weldings, but to me there is a clear difference between the two sides of the handlebars. On the left hand side the welding seems to be intact, whereas on the right hand side, it seems to me that the welding has given in, and the assembly itself is still intact. This can perhaps be seen even better on this photo taken from above:
For a professional welder like my neighbor it was no big deal to weld both sides again, and in the future I will need to keep an eye on these parts more often (y)
Best regards
Jens
   / Bcs 740 powersafe first run-in #30
Looks like the plate sheared on the left side and the weld started to crack on the right Jens. Did you take the assembly off or did your neighbor weld it on the tractor?
(APPROX. 20) 12" X 8'2" DECKOVER BUMPERS (A58375)
(APPROX. 20) 12" X...
1987 GMC C7000 Firetruck, VIN # 1GDM7D1G3HV526472 (A57453)
1987 GMC C7000...
UNUSED FUTURE CYHC MINI HYD 29" SIDE SHIFT FORKS (A58376)
UNUSED FUTURE CYHC...
Enerpac RCS302 30-Ton Low Height Hydraulic Cylinder, 5" Tall (A59076)
Enerpac RCS302...
UNUSED MOTOR OF INTERNAL CONCRETE VIBRATOR (A58376)
UNUSED MOTOR OF...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
