BBQ Smokers
/ BBQ Smokers #161
Test burn #3... this time I built a carcoal basket out of expanded steel. Same diam as the coal bowl and 4" tall. This way I can fit more and re-claim the 2nd cooking grate. I used a 1/2" stove gasket to seal the lid. I just put the lid in place and centered it as best I could... ran a bead of stove cement on the lid and set the gasket in place. Once that was dry I ran another bead on the top and bottom of the gasket. I also made a little 4" draft for the lid. 4- 1/2" holes.
Started at 2:30
275 at 3:00 draft closed
235 at 4:00 threw 3 sausage on
200 at 5:00 1/2 draft and added 6 briquets
220 at 5:30 3/4 draft
190 at 6:00 full draft and added 6 more briquets
190 at 7:30 full draft and added 6 more briquets
Getting there, but still not there. LOL So far it's only cost me $10 for the gasket plus a full bag of charcoal. I am happy that it seems to be going the right direction. The sausages were on there for about 4 hours and were really good... although I was pretty tipsy at that point so anything would have been good. LOL The gasket didn't seal the lid 100%. I added a hand full of wood chips twice and could see some wispers of smoke coming out in spots and around the feed door. Next is to seal the bottom.
/ BBQ Smokers #162
Gearhead, if you can maintain 190-210 then you don't really need to worry about leaks anymore. There has to be some exhaust or the fire will go out. Very few things are smoked at less than 190 and only electric smokers are easily controlled below that level.
/ BBQ Smokers #163
I thought 225-250 was ideal for most things.... so in saying that it seemed that I was still having too fast of a burn at the start using up too much fuel, not giving me long enough of a burn time and falling temperature. I could just keep adding coals, but it seems in-efficient.
Sealing up the bottom should be relatively easy. I plan to cut out a flange from light steel and weld it to the charcoal bowl. Basically extending the lip around the top of the bowl to where it will contact the smoker's body. Then I'll drill some holes in the bowl just below that lip for intake air. I'm thinking 4... starting at 1/4", then seeing what kind of temperature I can maintain. I can just drill the holes bigger until I get the results I want. I'll use the exhaust vent to regulate.
PS; sorry for the lack of pictures. My home computer's down, and I can't seem to be able to at work either. I'm pretty lacking in the IT department... I'll get some up soon... just might need help from the neighbor. LOL
/ BBQ Smokers #164
Indeed there are many meats that are smoked at 225 or so but I thought you were focused on getting control so you could lower the temp to under 200 which is needed for fish and some meats and fowl. "Low and slow" generally means using cooking temps of less than 225. Remember that basically anything will eventually equilibrate with the temperature of the oven so if you are cooking for 10-12hrs you can pretty much get the meat to close to whatever temp the oven is averaging. Even pulled pork doesn't require more than 210-220 to reach an internal temp of 200 in 10 hrs or so. For those occasions when you want higher heat, getting it up above 225 shouldn't require more than a bit more charcoal and fiddling with intake and exhaust drafts. The difficulty/challenge with most smokers is keeping the temp below 200 when necessary. I'm sure the boys with the BGEs or electronically controlled pellet smokers can manage a wider range of temps consistently but FWIW, I use my electric when aiming for temps in the lower smoker range and use charcoal in a Cajun Grill when higher smoking temps are possible. I find it tough to keep consistent 190-200 temps with charcoal in my dual purpose Cajun Grill. Then again I am still on the steep part of the learning curve so YMMV.
/ BBQ Smokers #165
Well I didn't get my Weber, but I was in Home Depot for something else when I spotted this;
Brinkmann Smoke 'N Grill Charcoal Smoker and Grill-810-5302-S - The Home Depot
$90 canadian. Figured I couldn't go wrong. Found some interesting mods on youtube such as putting in a real thermometer, putting the legs on backwards for easier access to the coal pan as well as drilling air vents in the pan for more air & heat. If it works out and I use it enough to make yummy meals it'll be easier to convince momma to get a nicer one. ;)
My next door neighbor just gave me one of those today. He got it for $40 barely used a couple months ago, liked smoking so much, he went and got a larger propane smoker a couple weeks ago and today asked me if I'd like to try it, and if I liked it, I could have it. :thumbsup: So, I'm cleaning it up a bit and will give smoking a try in the near future. :licking:
/ BBQ Smokers #166
Watch out, it's addictive and far more time consuming than grilling!!!
/ BBQ Smokers #167
I got time. :laughing:
I saw an electric element kit that slips in and out for use instead of charcoal. It costs about $40. Someone said to put a router speed control on it to dial it down if needed. I'll give it a try with charcoal a few times and see how it goes first. I have some ribs in the freezer that I can experiment with.
/ BBQ Smokers #170
FWIW...for anyone interested in smoking some meat or seafood etc...a fancy smoker is not mandatory ...
...All you need is something to hold the fire/wood chips and a rack for the meat etc...AND...a big enough cardboard box to cover everything...just cut a few vents where you want the smoke to escape and set it so it gets enough air under the bottom edges...
/ BBQ Smokers #171
Agree. A knowledgeable pitmaster with the simplest Weber kettle grill and a reliable thermometer could smoke just about anything successfully. The only advantage of dedicated smokers is bigger capacity and less need for monitoring.
Best smoked food I ever had (turkey) was from a roadside smokehouse in Florida that was literally a simple wood shed with a smoldering fire inside.
/ BBQ Smokers #172
That's the thing I liked about the old Cajun cooker and the Weber Smoky Mountain Smoker. They draw enough air to get the thing hot, but the water pan mitigates the temperature for a fairly low and slow cook. I have never needed to measure the temperature on either; just make sure you have enough charcoal and keep the water pan full. Chicken and turkey have a tendency (for me at least) to be a bit dry when cooked on the egg, but they always seem to turn out a lot more juicy on the Smoky Mountain.
I have cooked a turkey on the Weber kettle; it's a bit clumsy, but doable. I put a water pan on the bottom in the middle, and put the charcoal around the outside for indirect cooking. It takes some attention, what with having to remove the top, add water and charcoal, but like I said, it's doable.
/ BBQ Smokers #173
I'm going to smoke a couple of smallish filets of wild salmon today. Did the Alton Brown dry salt sugar pepper rub overnight (1/2 the salt after reading reviews) and will probably use my electric smoker to aim for lowish 150-160 smoking temps with apple chips.
Planning on a couple of whole chickens tomorrow in the Cajun Grill with charcoal and apple.
/ BBQ Smokers #174
What do you use for seasoning on your chicken?
/ BBQ Smokers #175
Anyone watch the recent Pit BBQ wars on cable??...it was several cook-offs in GA, AL etc...in all the competitions they had to cook chicken, ribs, pork butts and brisket...in almost all the cases the pit masters chose to submit thighs for their chicken entries...and they mostly did it the same way I have been doing it for 20+ years...
Remove the bone and all the fat from the thighs...there can be a lot of fat under the skin...in the competition on the cable show they all removed the skin...scraped all the fat from the under side and then re-covered the de-boned thighs...I usually just peel it back and get the majority of the fat out...smoked and or just grilled...I like a combo...low/slow smoke for a 2.5-3 hrs...then grill till done and crisp the skin and or caramelize a late added wet sauce etc...
For many years I used ' Loweries (sp?) Seasoned Salt"...then I found "Ryan's Butt Rub"...The Loweries was/is one of the ingredients I use if I make my own dry rub...any dry rub for beef...I use powered mustard...(a well kept secret by many better steak houses for bringing out the natural flavor of beef)
I like marinates but I've never ventured into injecting roasts etc....which you see a lot of on the competition shows...
For a change of pace I like marinating chicken (or beef) in Marsala and garlic etc...
In a pinch or intentionally...regular Italian dressing makes a decent marinate for any meat and especially good for fin or shellfish...
...The closest I've got to "injecting" is something 'Justin Wilson' liked to do...take a paring knife and push it to the hilt into a roast (pork/beef) and then push part of a clove of fresh garlic down into the bottom of the slot...it makes for an interesting roast...especially if you have a tooth for garlic...!...most of the pit chefs use apple or other fruit juices as a base for their injection marinates...
For most pork ribs (spare, country and Texas style) and chicken...I like adding a late bbq sauce and letting it "reduce" on the exterior when finishing on the grill...I always use honey in bbq sauce it adds some sweetness and it helps it stick, if I want a sweeter sauce I'll add a little brown sugar.
Back to chicken thighs...once the bone, fat and other unappetizing parts are removed they can be marinated/seasoned then rolled up, wrapped in the skin and they are ready for the smoker/grill...or for something a little different...drop the prepared thighs in some hot peanut oil until crispy...add a side of fried okra some biscuits and feast...!
/ BBQ Smokers #176
I'm probably going to inject with light brine and cider and then rub with Bad Byron's butt rub. Haven't tried the butt rub yet so thought I'd give it a try. I'm experimenting generally with smoking and should probably keep it simple. Going to use applewood again and try to keep the charcoal smoker at about 225. Haven't decided how to crisp the skin yet. Probably will just add some charcoal towards the end to get the smoker temp into roasting range.
By the way, the smoked salmon I made this afternoon (after curing overnight) was excellent even though I cooked it a bit more than I intended. Couldn't get the internal temp up above 135 after about three hours so I raised the smoker temp from 190 to 250 but 20 minutes later the internal temp was up to 175. I'd been aiming for 150. Not as moist as I had hoped but it was really delicious on crackers as an appetizer.
/ BBQ Smokers #177
...it was really delicious on crackers as an appetizer.
Make a spread with some cream cheese...great on a toasted bagel...!
/ BBQ Smokers #178
Good idea but I'm on the island and the nearest cream cheese is a ferry ride away. Maybe I'll keep some to try that but I'll surely remember to bring bagels and cream cheese next time I smoke fish. There is a fine fishmonger just near the ferry landing where I got the salmon and a good bagel joint just down the road too.
/ BBQ Smokers #179
If you use a rubb, I would suggest that you prepare the chicken ahead of time and let it sit overnight. It seems to enhance the flavor of chicken, at least in my opinion, in a noticeable way. Lemon pepper is also a good seasoning for chicken, especially when it's grilled.
/ BBQ Smokers #180
Too tired to do it tonight but I'll put the rub on first thing in the morning and start cooking six hours later.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
Ford Tractor (A62613)
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
