Quick Hitches BB hitch pin spacers? No quick hitch
   / BB hitch pin spacers? No quick hitch #1
al3
Central Wi
JD 4110, X500
Began using a Woods made Frontier BB to make a fire break. The BB is designed to be quick hitch compatible, so the lift arm attaching set up uses removable hitch pins. When used without a quick hitch, there’s a lot of slop, i.e several inches lateral movement of the ball on the hitch pin.(in other words, the stinkin' BB can slide sideways)
It’d also be nice to narrow the lift arms they’ll rub on the tires (at ½ to full lift) when the BB sways to one side or the other. (been using it as ballast for FEL work; when I turn on sloped ground the lift arms will rub on one side). Tractor came with turnbuckles to limit sway to some degree, but they’re at minimum length.
I assume the easiest remedy is to buy a pair of linkage bushings, cut them down and use ‘em as spacers to pin the lift arms as narrow as possible? Can't see why this wouldn't work, but before I screw-up a set of lift arms/balls, thought I'd ask. Thks.
   / BB hitch pin spacers? No quick hitch #2
al3,
I use 7/8" or 1" flat washers to take up the slack in my woods BB, works great. I'm just not sure which size I used.
Bill
2012 John Deere 6170R (A57148)
2012 John Deere...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
John Deere 1025R (A53317)
John Deere 1025R...
set of 4 tractor trailer tires Roadforce (A61306)
set of 4 tractor...
