Battery specs for PT-425
/ Battery specs for PT-425 #1
Frank Sorbello
Power Trac PT-422
Looking for a new battery for PT-425. Anyone know what the cold cranking amps, size etc... should be. And a good source for purchasing one.
Thank you,
Frank
/ Battery specs for PT-425 #2
I just replaced mine in September. It’s a rare size and my local Interstate distributor only had one in stock. I couldn’t find a direct replacement at Batteries Plus or any parts store chains. Seems like I might have found one orderable at Lowe’s or Home Depot which was my backup plan.
Interstate Part number SP-45
Group size 45
CCA 480
CA 600
/ Battery specs for PT-425 #3
Look at the specs on your existing battery. Should be a label on top with the info.
Generally, I try to get a replacement battery with the highest cca’s I can find in the correct size.
NAPA usually has a wide selection of batteries if you have one close by. Tractor Supply generally has a good selection too.
/ Battery specs for PT-425 #4
On my 2425 I had to think outside the box, literally. It took care of my hard start when it dips down in the single digits where I live. I keep it parked outdoors. I have a 750 cca battery now with a little more umph. Also notice the welding cables for battery cables, works very well.
/ Battery specs for PT-425 #5
@Tchamp Nice! I replaced the Power-Trac cables when I got mine as well.p, as I have had too many issues with "standard" cables not being up to the task when old.
I'm sure that you are super careful, but if it were me, I would at least cover up the positive terminal. I could see myself accidentally shorting it to ground, doing something stupid like having a wrench fall out of a pocket...
All the best,
Peter
Deere 410L (A53317)
Deere 410L (A53317)
2023 LEEBOY 8530 ASPHALT PAVER (A60429)
2023 LEEBOY 8530...
(2) 3"X36" HYD CYLINDERS (A60430)
(2) 3"X36" HYD...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
(8) UNUSED IRANCH 9'X5' WROUGHT IRON SITE FENCE (A60432)
(8) UNUSED IRANCH...
