Battery specs for PT-425
   / Battery specs for PT-425 #1
Frank Sorbello
Power Trac PT-422
Looking for a new battery for PT-425. Anyone know what the cold cranking amps, size etc... should be. And a good source for purchasing one.
Thank you,
Frank
   / Battery specs for PT-425 #2
I just replaced mine in September. It’s a rare size and my local Interstate distributor only had one in stock. I couldn’t find a direct replacement at Batteries Plus or any parts store chains. Seems like I might have found one orderable at Lowe’s or Home Depot which was my backup plan.
Interstate Part number SP-45
Group size 45
CCA 480
CA 600
   / Battery specs for PT-425 #3
Look at the specs on your existing battery. Should be a label on top with the info.
Generally, I try to get a replacement battery with the highest cca’s I can find in the correct size.
NAPA usually has a wide selection of batteries if you have one close by. Tractor Supply generally has a good selection too.
   / Battery specs for PT-425 #4
On my 2425 I had to think outside the box, literally. It took care of my hard start when it dips down in the single digits where I live. I keep it parked outdoors. I have a 750 cca battery now with a little more umph. Also notice the welding cables for battery cables, works very well.
   / Battery specs for PT-425 #5
@Tchamp Nice! I replaced the Power-Trac cables when I got mine as well.p, as I have had too many issues with "standard" cables not being up to the task when old.
I'm sure that you are super careful, but if it were me, I would at least cover up the positive terminal. I could see myself accidentally shorting it to ground, doing something stupid like having a wrench fall out of a pocket...
All the best,
Peter
Year: 2016 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A55788)
Year: 2016 Make...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Killbros 350 Gravity Wagon (A50775)
Killbros 350...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
