Battery powered chainsaw
/ Battery powered chainsaw #851
I use my Kombi with up to 2 extensions, when I want a powered pole saw. Works great, although I think they technically only "approve" use of one extension.
I do two sections with my pole saw head sometimes. Did it this week with a hedge trimmer head to reach far enough.
Problem with both is that they get heavy and hard to control easily. The pole saw only weighs maybe five pound or less, but when you get it out there on the end of a ten foot stick, it feels like a lot more.
/ Battery powered chainsaw #852
Yeah, for sure! I'm usually using mine for vertical reach, so while it's a bit like a caber toss balancing act, at least I'm not trying the hold the weight cantilevered out horizontally.
/ Battery powered chainsaw #853
When trimming along the tree line, I raise the tractor FEL forks about 8'. Standing on the ground, I lean the pole saw against a fork to take some of the weight off. That way, I can use all 3 extensions. I trim one area and move the tractor down the line.
I saw one farmer down the valley, use a 10' FEL mounted boom pole the same way.
/ Battery powered chainsaw #854
I'd guess it must be a bit of a thing getting it started with three extensions? I notice how much the engine wants to bog on starting, with each added extension. Never even tried 3!
I bought the largest engine available at the time (6-10 years ago?), which I suspect is the KM 131 R I see on their site now, but I'm not running out to the shed to check right now!
/ Battery powered chainsaw #855
I bought a Stihl Kombi brush cutter and it worked as well, if not better, than my old gas unit. Need to buy a saw blade for larger diameter saplings to finish "the test" but the brush cutter worked. The batteries lasted as long, if not longer than a tank of gas/oil mix and was MUCH quieter.
Suspect I will get the Stihl chainsaw soon. The price is going to hurt but I am tired of messing with gas.
/ Battery powered chainsaw #856
So far happy with stihl AP series... but it's a commitment to be sure.
/ Battery powered chainsaw #857
I have the Ryobi 40 volt battery attachable string trimmer with pole saw attachment, Hedge trimmer attachment and tiller attachment. All work ok for certain uses but not for everything. The pole saw works good for smaller limbs up to 3 inches with the extension on but it gets heavy to hold with the extension on for very long. I also Ryobi 40 volt chainsaw and Greenworks 60 volt 20 inch chainsaw, love them both and only use my Husky 395 xp gas saw for large trees
/ Battery powered chainsaw #858
We went out to do some tornado cleanup in Evansville this week. We carry 5 different chainsaws, some Stihl, some Husqvarna. We were cutting with two sawyers for about 5 hours. My Greenworks Pro will run MAYBE 20-30 MINUTES. In the real world, battery saws are just not capable of doing a days work.
/ Battery powered chainsaw #859
Not news to me, but when we back-pack in they are still good to have along or on the atv when there "might" be sawing. Carry extra batteries and knowing that the cutting is minor. (y)
2012 FORD F-250 (INOPERABLE) (A60736)
2012 FORD F-250...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
1042 (A60430)
1042 (A60430)
Approximately 110 Miscellaneous Desktop and Mini Computers (A59317)
Approximately 110...
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
