Battery powered chainsaw
/ Battery powered chainsaw #1,271
How thick are you cutting? 2-3" at most?
Seldom over 6-7 inches but we do go to 18 feet for lobby and institutional trees.
/ Battery powered chainsaw #1,272
18 foot cut?
18 foot tall tree here would be a sapling. Obviously not when intended as a Christmas tree. ;)
/ Battery powered chainsaw #1,273
I bought a Worx 10 inch chainsaw on a pole to trim branches overhanging the house. After shoulder surgery, I have found it extremely difficult to pull start just about anything. I was impressed with the 10 inch saw, so I bought the 16inch dual battery brushless Worx saw. I have been very pleased with It. I have 2 sets of batteries for it. So far the battery life lasts about as long as my stamina.
I have a tow-behind rotary rough-cut mower. Pull-starting it was at my limit of ability, if it started easily. If it was going to be a booger to start, and I kept at it, I had a rather painful shoulder as a result. So, I converted it to start using a socket in a battery drill, with a ratchet coupling for added safety. A backfire can hurt one's wrist if holding the drill too tightly.
/ Battery powered chainsaw #1,274
A year or so ago I bought a Stihl MSA220C saw with an AP300S battery and charger, at that time it was Stihl's biggest and best battery chainsaw. Since then they have brought out a bigger model. All up it cost me AUD 1,300. For that price I could have bought four MS170s, the petrol saw which I feel is about equal in power/ cutting ability to the battery saw.
The saw gave me about 15 minutes of cutting with the type of firewood I use. Yes it was very convenient to just put in a battery and pull the trigger and cut, and not having it sitting burbling away while picking up and stacking pieces of wood between cuts was also good, as was not having to pull on the starter cord to get it running again. However my MS170 cut about 4 times the amount of firewood per tank of fuel.
One thing not mentioned so far on this thread is that if using the saw beginning with a fully charged battery and cutting continuously until the battery drains to flat then it cannot be charged until it cools down which can take around half an hour and once cooled down it takes about 40 minutes to get fully charged again.
A petrol saw can be refilled in seconds and be back cutting without delay.
So, to get the same amount of firewood cut within the same time frame I would need to have at least three batteries on hand and they cost AUD 300 each.
I managed to sell the saw, charger and battery to a friend who only does a little cutting.
Yes, there is a place for battery saws but the present cost of the batteries means they are for those with plenty of money.
Yes--that third paragraph is something I've not seen mentioned anywhere in any threads about battery saws! It is very true also. Hot, spent batteries "need" to cool down before they'll accept a charge. Not a problem for me as I'm an occasional user and have several batteries but it is a problem for anyone that doesn't.
/ Battery powered chainsaw #1,275
We did the same at the Christmas Tree Farm with opposite outcome.
Had 4 170 Stihl gas saws we replaced with 2 Stihl battery saws.
Hundreds of fresh cuts each Christmas season day on peak days.
The gas saws required 4 to have 2 ready and hundreds of starts proved hard on rope pulls and staff would flood and noise ordinance meant hand cuts in the evening hours.
Two battery saws always at the ready and one battery can do hundreds of cuts… 2 saws with 3 batteries and one quick charger.
That's the way to go ultra! Extra batteries & a quick charger.
/ Battery powered chainsaw #1,276
Barely related, but I have an occasional project where we have to use a biscuit joiner tool over and over in a very hard wood. It gets hot quickly especially on a hot day, so I do what's needed on one panel, chuck the tool into the fridge, do the rest of the work for that panel, get the tool out of the fridge, repeat
/ Battery powered chainsaw #1,277
Only if you disregard the manufactures guidance on fueling. They all say that you should let the engine cool before adding fuel.
That where you ice filled cooler comes in. Put the battery in the cooler for 10 minutes and it will be cooled down enough to put on the charger.
Richard
/ Battery powered chainsaw #1,278
Richard
Do you know one person that actually does that? Literally everyone pours gas in and gets back to work.
/ Battery powered chainsaw #1,279
Grandpa… he would run the saw dry and take a break before refueling and then repeat depending on ambient temperature.
/ Battery powered chainsaw #1,280
Now that I've been a grandpa for more than decade I do as well. Heck often before it runs dry nothing to do with the saw.....
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Bronco Sport 4x4 SUV (A59231)
2021 Bronco Sport...
240156 (A56859)
240156 (A56859)
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2014 Freightliner Bucket Truck (A61307)
2014 Freightliner...
