Battery Light
/ Battery Light #1
loopyl
Vermont
My L4400 only has 7 hours on it. The battery light won't turn off after the engine is started. It seems to be running fine, but do I have to worry about something? Everything seems to be hooked up right. Alterrnator? Loose wire? I cannot find a diagram anywhere that shows me what everything is supposed to look like. Can anyone help?
/ Battery Light #2
I would look for a missing belt on the alternator. Pop the hood and make sure the alternator is turning when the engine is running.
I had some brush reach in there and pop-off my water pump belt the second day I used my tractor. The first clue was the overtemp alarm!
/ Battery Light #3
You do have to worry. Either you have a light that is malfunctioning (on when it shouldn't be) or your charging system isn't working. If you aren't charging, you're running entirely on your battery. Since it is a diesel it won't behave the same as a gas engine (no spark plugs drawing power) but eventually it will fail to start. As suggested, checking the alternator belt is a good place to start. A loose wire (check to see if any of the connectors are not making good contact) is also a distinct possiblity.
Tracking down electrical issues can be a real chore. With only 7 hours this is something your dealer should take care of for you.
John Deere Starfire 6000 (A64126)
John Deere...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
SKID STEER FORKS (A62613)
SKID STEER FORKS...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
