Battery Light
/ Battery Light #1
loopyl
Vermont
My L4400 only has 7 hours on it. The battery light won't turn off after the engine is started. It seems to be running fine, but do I have to worry about something? Everything seems to be hooked up right. Alterrnator? Loose wire? I cannot find a diagram anywhere that shows me what everything is supposed to look like. Can anyone help?
/ Battery Light #2
I would look for a missing belt on the alternator. Pop the hood and make sure the alternator is turning when the engine is running.
I had some brush reach in there and pop-off my water pump belt the second day I used my tractor. The first clue was the overtemp alarm!
/ Battery Light #3
You do have to worry. Either you have a light that is malfunctioning (on when it shouldn't be) or your charging system isn't working. If you aren't charging, you're running entirely on your battery. Since it is a diesel it won't behave the same as a gas engine (no spark plugs drawing power) but eventually it will fail to start. As suggested, checking the alternator belt is a good place to start. A loose wire (check to see if any of the connectors are not making good contact) is also a distinct possiblity.
Tracking down electrical issues can be a real chore. With only 7 hours this is something your dealer should take care of for you.
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
IH International 1466 Tractor (A66285)
IH International...
