Battery Disconnect
/ Battery Disconnect #1
R Barger
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV X900 Mahindra 4540 4WD w/Loader
I have a battery disconnect on my Kubota X900 RTV that I park in my basement for safety reasons. My question is can I put one on a Mahindra 4540 tractor that I recently purchased? It has a ECU that mainly controls the injection system I believe. Will disconnecting the battery on a regular basis cause a problem in any way? I'm parking the Mahindra in my shop and thought it would be a good thing to do with it also.
/ Battery Disconnect #2
It won't cause any issues. You can install the battery disconnect.
Here in Europe, since 2018 or so, all equipment just come standard with the disconnect, regardless on how much electronics it has.
Putting on the hot side should kill all the power. I would use a maintainer as well.
Just wanting to feel comfortable that I not destroying a expensive ECU.
I have always installed on the negative side. Maybe I'm wrong.
I have been using one of these for about a year with no issues:
I've never considered one of these. Would be nice if dependable.
/ Battery Disconnect #8
It’s nice because you don’t have to open the hood to turn it off or on. You could put a conventional kill switch in the cabin but I was too lazy to run cables so the remote switch was worth it.
I had to do something because there was a parasitic draw. Mechanic traced it to the instrument panel and quoted $750to fix it. A $30 solution worked.
The mechanic saw it on my next visit and ordered one for his plow truck that sits idle for long periods of time.
/ Battery Disconnect #9
All heavy equipment from past to present have a master shutoff. The new Cat equipment we have at work have so much computer garbage in it now it’s crazy. From skid steers to dozers and everything in between. It all gets the master switch shut off at the end of each day. Now during the winter months all the equipment sits outside until spring. It always fires right back up.
/ Battery Disconnect #10
My tractor, a Ventrac 4500Y, came factory-equipped with a battery isolation switch. The Ventrac’s control module, which Ventrac calls the Tractor Control Module, will enter a sleep mode if the tractor sits for two weeks without being turned on with the ignition switch. If the TCM goes to sleep, then the user must, for a brief interval, remove power from the TCM by opening the battery isolation switch. Then the user must reapply battery power bu closing the battery isolation switch. The TCM will then reboot, and the glow plugs will receive current when the ignition key switch is placed in the On position, and the starter will crank when the ignition key switch is turned to the Start position.
/ Battery Disconnect #11
Hot side ? I haven’t read any instructions for installing a battery disconnect but I believe it’s supposed to be installed on the negative side.
Edit
I just read some instructions for installing battery disconnects and yes they are supposed to be installed on the negative side.
/ Battery Disconnect #12
anything like a car or truck with a ECM or PCM computer then everytime you disconnect the battery the computer has to go through a relearn process . on cars and trucks it takes 5 miles of normal driving of stop and go and a long run for it to relearn. I can imagine it's the same with the tractor. the computer will have to go through a relearn process. I would not recommend a disconnect on it.
/ Battery Disconnect #13
Edit
It is supposed to be on the negative side.
/ Battery Disconnect #14
Edit
You should install a battery disconnect switch on the negative (ground) side, as this provides maximum safety by interrupting the path to the vehicle's chassis, preventing sparks and shorts if the positive (hot) side accidentally touches metal, and it's the standard practice for most vehicles, preventing issues like alternator power sustaining the circuit even if the positive is cut.
/ Battery Disconnect #15
Edit
Current flows from the negative terminal (-) to the positive terminal (+).
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
TANK MANIFOLD (A58214)
2017 Subaru Impreza AWD Hatchback (A59231)
2017 Subaru...
