Battery Disconnect
/ Battery Disconnect #1
R Barger
Gold Member
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV X900 Mahindra 4540 4WD w/Loader
I have a battery disconnect on my Kubota X900 RTV that I park in my basement for safety reasons. My question is can I put one on a Mahindra 4540 tractor that I recently purchased? It has a ECU that mainly controls the injection system I believe. Will disconnecting the battery on a regular basis cause a problem in any way? I'm parking the Mahindra in my shop and thought it would be a good thing to do with it also.
/ Battery Disconnect #2
It won't cause any issues. You can install the battery disconnect.
Here in Europe, since 2018 or so, all equipment just come standard with the disconnect, regardless on how much electronics it has.
/ Battery Disconnect #4
I also have one that I’ve never installed because I was concerned about doing something to fry the ECU
Putting on the hot side should kill all the power. I would use a maintainer as well.
Just wanting to feel comfortable that I not destroying a expensive ECU.
I have always installed on the negative side. Maybe I'm wrong.
I have been using one of these for about a year with no issues:
I've never considered one of these. Would be nice if dependable.
/ Battery Disconnect #8
It’s nice because you don’t have to open the hood to turn it off or on. You could put a conventional kill switch in the cabin but I was too lazy to run cables so the remote switch was worth it.
I had to do something because there was a parasitic draw. Mechanic traced it to the instrument panel and quoted $750to fix it. A $30 solution worked.
The mechanic saw it on my next visit and ordered one for his plow truck that sits idle for long periods of time.
/ Battery Disconnect #9
All heavy equipment from past to present have a master shutoff. The new Cat equipment we have at work have so much computer garbage in it now it’s crazy. From skid steers to dozers and everything in between. It all gets the master switch shut off at the end of each day. Now during the winter months all the equipment sits outside until spring. It always fires right back up.
/ Battery Disconnect #10
My tractor, a Ventrac 4500Y, came factory-equipped with a battery isolation switch. The Ventrac’s control module, which Ventrac calls the Tractor Control Module, will enter a sleep mode if the tractor sits for two weeks without being turned on with the ignition switch. If the TCM goes to sleep, then the user must, for a brief interval, remove power from the TCM by opening the battery isolation switch. Then the user must reapply battery power bu closing the battery isolation switch. The TCM will then reboot, and the glow plugs will receive current when the ignition key switch is placed in the On position, and the starter will crank when the ignition key switch is turned to the Start position.
/ Battery Disconnect #11
Hot side ? I haven’t read any instructions for installing a battery disconnect but I believe it’s supposed to be installed on the negative side.
Edit
I just read some instructions for installing battery disconnects and yes they are supposed to be installed on the negative side.
/ Battery Disconnect #12
anything like a car or truck with a ECM or PCM computer then everytime you disconnect the battery the computer has to go through a relearn process . on cars and trucks it takes 5 miles of normal driving of stop and go and a long run for it to relearn. I can imagine it's the same with the tractor. the computer will have to go through a relearn process. I would not recommend a disconnect on it.
/ Battery Disconnect #13
Edit
It is supposed to be on the negative side.
/ Battery Disconnect #14
Edit
You should install a battery disconnect switch on the negative (ground) side, as this provides maximum safety by interrupting the path to the vehicle's chassis, preventing sparks and shorts if the positive (hot) side accidentally touches metal, and it's the standard practice for most vehicles, preventing issues like alternator power sustaining the circuit even if the positive is cut.
/ Battery Disconnect #15
Edit
Current flows from the negative terminal (-) to the positive terminal (+).
/ Battery Disconnect #17
Arguing over a disconnect on the + or the - is probably a non issue if the disconnect is sized for the battery post. Which from memory is always the negative.
/ Battery Disconnect #18
However Some older tractors do use positive ground systems.
/ Battery Disconnect #19
Electrons flow from the negative terminal of a battery (or other form of power supply) to the positive terminal. Electrical Engineers observe a “current convention” in which the flow of current is from positive to negative… opposite to the flow of electrons.
The isolation switch on my Ventrac 4500Y is on the positive leg of the electrical system circuit.
I really don’t see a disadvantage if an isolation switch interrupts the circuit from the positive side of things. I also do not see an advantage if an isolation switch breaks the circuit on the negative side of the supply.
/ Battery Disconnect #20
According to OHMS law it takes one volt to push one amp through one ohm of resistance.... Providing there is a loop circuit from one battery pole to the other battery pole.... Open the loop any place and you have no current flow (path)......There for you are "disconnected"....
Big Tex 16TL20 20' Tilt Trailer (A64127)
Big Tex 16TL20 20'...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
TR 23 QA Mini Trencher (A64127)
TR 23 QA Mini...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
