Battery / Charging Lite
/ Battery / Charging Lite #1
arthr31
Platinum Member
new england
3 Yanmars
Hey all:
Was working with my 1601d on Sunday for a few hours /forums/images/graemlins/grin.gif box blading and brushhogging. A good time overall... But, while working, early in the afternoon (went from 1pm to 530) the battery / charging lite would come on, then go off. sometimes it'd come on and stay on for many minutes. I shut down, ran back to the house and looked it up. Manual says it could be fan belt (is OK), altenator (looks ok, but who am i to know), regulator (same), or battery (new).
So, I started back up thinking, well, i can continue working for now... Anyway, worked for the rest of the afternoon and never saw the lite come back on. anyone care to speculate on this? I'm going to check the battery today and see if it's down or losing charge...
also, just for clarrification, this is the lite on the upper left hand part of the 1601 panel...
as always, thanks for the advice /forums/images/graemlins/smile.gif -arthr
/ Battery / Charging Lite #2
Next time you run back to the house, pick up a volt meter /forums/images/graemlins/wink.gif.
good idea!
I can test the regulator with that, right? Is there anyway to test the altenator (without removing it)??? Thanks! -arthr
/ Battery / Charging Lite #4
Measure static volts on the battery, and then charging volts on the battery. static could be anything up to 12.6v. Charging volts will be 13.2 to 14.7 in general.
You can also set to an ac scale and measure the alternator output.
If you have a clamp on ammeter, or a high capacity ammeter function, you can also check charge current.
Soundguy
Thank you. Didn't get a chance to go out and try any tests today... Having a 'noreaster here and I have a flu. Who sez winters over?!? /forums/images/graemlins/shocked.gif But, anyway. I'll try and hook up some test equipment to it and see what I get.....
/ Battery / Charging Lite #6
I'm pretty sure your YM1601 has the rectifier, (changes AC to DC), in the regulator, so if you find it is not charging you can unplug the regulator from the alternator and briefly run the tractor, looking for approx. unregulated 20-30VAC from the alternator. If present, then regulator is bad. If no 20-30VAC, alternator is bad, (but reg. could be also). It's usually the regulator, and unfortunately, I don't know of any aftermarket units for this model.
/ Battery / Charging Lite #8
My 1602D did this a couple of times when I first got it, turned out it had the wrong alt belt installed and it was slipping under load (didn't fit the pulleys correctly). I just put a new belt on and it's fine. Check the belt carefully, could be all it is. However, to change the alt belt, you have to remove the lower radiator hose, so you might as well change your antifreeze and flush the cooling system while you're at it, if you haven't done so recently.
hey all, thanks for the feedback. lotsa good ideas to check... now, just to make sure what i'm talking about, here's a pic of which lite is glowing intermittently. The lite which glows, has the white arrow to it.
after verifying this in both my ym180 and ym169 owners manuals, neither of these tractors even have this warning indicator on their panel. If I guess correctly, this lite is warning 'bout a bad battery?!? maybe? The battery is new, has adequate water in it too. The only thing I can check for is specfic gravity since I don't have a hydrometer (right?). Also, I still haven't had a chance to hook up a test to the battery.. maybe tomorrow, it's raining like CRAZY tonight... Thanks again. -arthr
/ Battery / Charging Lite #10
That's a low battery water indicator. Japanese batteries have a low battery sensor with 2 wires going to it. there should be 2 loose wires ending somewhere near the battery. Short them together, tape them up, and the light will stay off.
thank you, sir! I'll look for those wires later... -arthr
/ Battery / Charging Lite #13
Another proper diagnosis via a good picture! Well done, TBN!
Ford 3910 Tractor (A65579)
Ford 3910 Tractor...
(16) Kinze 3000 Precision Plant Corn Meters (A65640)
(16) Kinze 3000...
E-Ton Viper RXL-50 FOURWHEELER (A62613)
E-Ton Viper RXL-50...
1999 Coachman Catalina RV/Camper VIN # 3FCMF53S2XJA29020 (A65563)
1999 Coachman...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
