Battery Cell Fluid Level Check
/ Battery Cell Fluid Level Check #1
mmranch
Crested Butte, CO
TYM T603
My tractor battery is an ATLAS BX BX110BR and is 15" wide with a flat top and two terminal posts. There is also a small looking glass hole which shows the color blue when the battery is good. There are no normal caps on the top to check cell fluid level.
But when you look at the battery flat top, there are screwdriver slots on both ends of a section of the flat top. Makes me wonder if that section somehow pops off and allows checking the cells? Are tractor batteries like this serviceable for checking the cells?
The battery still charges and the looking glass shows blue but with it's age, I'm worried the cells may be drying out.
Thanks!
I should also note that I put a screwdriver in the slots and tried to pry the section off and the battery lifted up so the section does not come off easily.
Thanks!
/ Battery Cell Fluid Level Check #3
Many newer batteries are sealed and you cannot readily add fluid. If you don't let the battery go dead it should last five to ten years.
/ Battery Cell Fluid Level Check #4
About all the batteries I have bought in the last several years have been low on electrolyte. Added distilled water to bring them up.
Thanks for the ideas! I guess this battery may be nearing the end of it's life as it's probably 12+ years old now.
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A66736)
2017 Volvo VNL T/A...
2019 KOHLER 38RCL Generator DISCONNECT ATS 38KW 315 HORS (A66734)
2019 KOHLER 38RCL...
2012 DIAMOND T TRAILER GOOSENECK TRAILER (A67714)
2012 DIAMOND T...
2022 CASE CX145DSR EXCAVATOR (A65053)
2022 CASE CX145DSR...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2020 CATEPILLAR 289D3 SKID STEER (A65056)
2020 CATEPILLAR...
