Battery acid spew...
/ Battery acid spew... #11
Yes, Optima, its a NH/Kioti dealer. No it is not a sealed battery, the tops pop off no problem at all, its charging at 14.5volts according to my meter (at idle and 2000rpm's). Sorry for the late reply but I just got back from the cottage.
Steve
/ Battery acid spew... #12
<font color="blue"> Yes, Optima, its a NH/Kioti dealer. No it is not a sealed battery, the tops pop off no problem at all, its charging at 14.5volts according to my meter </font>
Hmmm.......The real Optima Battery company may like to hear of this, but then again he is in Canada too.
/ Battery acid spew... #13
Jerry, You peaked my curiousity, I just ran out to the shed to look and I lied, its a New Holland battery that has Optimum written on it. Sorry for the confusion.
Steve
/ Battery acid spew... #15
Steve for optimum performance replace the Optimum with a Optima battery. Are we confused here yet? /forums/images/graemlins/confused.gif
/ Battery acid spew... #16
the boss's green 4400 JD almost 2 yrs old, ate the hyd cooling unit from this! they are giving free parts but he has to do work or bring it in, can't load it up so had to do it... seems like a bad thing. mine leaked a bit prior to oepning up the little breather holes as some of them pressurized the china battery and caused a bit of spew... washedit all off and seems OK now. but i have to check the level pretty soon as it;s already got frost warnnings for tonight /forums/images/graemlins/blush.gif /forums/images/graemlins/frown.gif where did SUMMER go or for that metter SPRING? /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif
Mark M
Ron, I am glad to hear you haven't had any problems!
Please note, I knew that Deere owners were having issues, so I checked mine regularly. But, only when I took my battery out did I discover hidden damage.
I don't think that it is a quality issue. It just seems to be related to type of use. If the tractor bounces a lot, especially under heavy use, like bush hogging a pasture. Heat, bouncing and a high speed radiator fan might be combining to make a mess...
Here is a link to the Strongbox Batteries. Sure seems like Deere is serious about their quality...
And here is a Deere branded Optima (type) Spiral Cell Battery.
/ Battery acid spew... #18
Add me to the latest of 4310 owners with battery acid indigestion. This is my 2nd battery in the 3ish years. I've been reading this thread and dreaded looking at mine. It is so bad that the clips that thread the bolts for the hold down tabs on the battery were just crusted clumps and wouldn't unthread. I took it to my local deere dealer (where we didn't by it from) and I talked to the service guy who is on the ball. The owner is a dud (and why my wife went down the road to buy the tractor). The service guy said he hadn't heard of such troubles, but that it sounded like the battery was getting cooked (overcharged). He is talking to deere about it. I am probably out of warranty and outta luck. For you sealed battery fellows is there a problem of overcooking sealed batteries? I thought you had to trickle charge them
/ Battery acid spew... #19
An achilles heal with Toyotas is battery post corrosion. My Tacoma even leaked battery acid down the side as described on your tractor.
The solution, believe it or not, was the installation of a pair of those pads underneath where the battery cables attach. I have not had a bit of trouble with corrosion or leaking battery acid since installing these felt pads.
My new Gravely battery bought from Central Batteries in town (Charlottesville) came with those felt pads on the terminals.
I use them on all my vehicles now. No post corrosion at all.
Ralph
/ Battery acid spew... #20
</font><font color="blue" class="small">( I read about the battery acid issues here and replaced mine with an optima redtop also. Sucking acid fumes through the radiator didn't appeal to me! )</font>
I didn't see an application chart for tractors on the Optima display, nor did the salesman know what battery my L3010 needed. Is there a fit guide online somewhere..?
Pete
2018 Merlo TF30.9 115 (A60462)
2018 Merlo TF30.9...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2020 Deere 317G (A60462)
2020 Deere 317G...
2012 John Deere 8235R (A60462)
2012 John Deere...
