Battery acid spew...
/ Battery acid spew... #22
Just talked with dealer and with the 4310 and Deere has known about the problem and new tractors should be coming with sealed batteries. They are looking into my problem. Baking soda and water is all the answers for now I have recieved.
/ Battery acid spew... #23
Not directed at anyone in particular, but just a little information from high school chemistry. When you neutralize battery acid with baking soda and water, the resulting compound is NaCl (sodium chloride) or salt. Make sure you wash the battery compartment with soap and water to remove the salt.
HTH
Leroy
/ Battery acid spew... #24
I got digging into the leaky battery a little deeper and discovered that the acid level I think is too high. The dealer had the acid right to the top thus when the battery tries to relieve any pressure it pushs acid out as the cap vents are submerged in the acid. I removed enough acid to leave about one inch over the plates and now there is about an inch between the acid level and the vent tube on the battery cap. Will report if this is a solution to the leaky battery.
Steve
/ Battery acid spew... #25
</font><font color="blue" class="small">( When you neutralize battery acid with baking soda and water, the resulting compound is NaCl (sodium chloride) or salt. )</font>
Sorry for the nit-picking comment here, but battery acid and baking soda make three products: water, carbon dioxide, and sodium sulfate. No sodium chloride is made, although it's still great advice to rinse everything off really well.
/ Battery acid spew... #26
Well, in my defense, I only heard it once when I was awake in high school chemistry (a long time ago in a galaxy far, far away), but I have noticed that the battery box will still continue to rust if you don't wash and rinse after you use baking soda and water to neutralize acid.
/ Battery acid spew... #27
Follow-up, used tractor for about two hours with and without backhoe, plenty of bouncing around and no acid leaked out of the vents so far.
Steve
So, before you lowered the fluid level, you were able to detect leakage?
/ Battery acid spew... #29
"discovered that the acid level I think is too high"
I just bought a new riding lawnmower battery a few weeks ago and had to fill it, seemed to take 2 steps to get it right, Had to wait quite a while for the bubbles to get out and for the acid to saturate the plates before I could get the level right. And yes they will overflow when charging if the electrolyte level is too high. Maybe the acid spew is not a design problem but a common dealer setup problem. This would explain why some owners have the problem and some do not. Just a thought based on my experience with filling batteries. Makes me feel better about the tractor engineers.
Ben
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
Zero Turn Mower (A59231)
Zero Turn Mower...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
