Kubota engine difficult to turn over when cold (not battery)
   / Kubota engine difficult to turn over when cold (not battery) #21
I think....it is a loose electrical connection. Besides battery cables, there are other wires going to/from the starter solenoid and switch. I think your heating the glo plugs and crank attempts is shaking or heating up a loose connection. "check every connection."
Every connection (including the battery posts and clamps) needs to be clean, bright and free of corrosion and apply di electric grease to each connection to keep it clean and bright.
One of the most neglected connections is the negative cable to chassis ground. What I do with that one as well as others, besides the cleaning and di electric grease application, I use toothed (external or internal) lockwashers, The teeth will bite into the metal and provide a long lasting low resistance connection, much better than the standard split lockwashers.
Well if it is a loose connection it has had one since it was new. I have replaced cables, positive & negative, polished grounds. I have checked every connection that I have found.
   / Kubota engine difficult to turn over when cold (not battery) #23
A starter current draw test might be in order. Bad starter shaft bushings cause the starter to drag.
   / Kubota engine difficult to turn over when cold (not battery) #24
Optima's were good until Johnson Controls sub contracted most of them offshore. Then they went downhill rather quickly. Far as I know, the only ones still produced at the Waterville, Ohio plant are the blue top marine batteries. My farm is about 20 miles north of them.
I just buy my flooded cell jars from a volume dealer now, in my case the local Freightliner dealer I retired from. They go through batteries like water so they are all fresh. Been using the Delphi brand, not sure who makes them but I have excellent luck with them. Personally speaking, I think Optima's are over priced and poor quality (life) today.
Neither of my Kubota M9's have a timer on the glo plugs, I just do the second count in my head and never more than 10 seconds no matter how cold it is outside. If they aren't red hot in 10 seconds, you have other issues (like a weak battery) for instance.
Mine are a bit older than yours, 2002 and 2004.
One can read that all things are "good" and on another forum all things are "bad" on the internet. Lots of experts abound on all subjects. Sometimes it's entertaining.
For my own personal experience with Optima batteries, I've never had one fail. Started buying them 20-odd years ago, and every time, they've worked fine. I put a blue top "dual purpose" marine/rv battery (blue top, light grey body) in my '74 Dodge Power Wagon that was still going strong 10 years later when I sold the truck in the fall of 2011. It always had enough juice to start up that 11:1 compression 440 big block.
I put a red top Optima in wife's Toyota 4Runner the first winter we moved up here (2011). It's still there, and never had a single issue with it. The first time it got *cold* here, it killed the original OEM battery. 11 YEARS later, that red top Optima is still in her car, and still fine. Never needed a jump or failed to start. Ever. Last year was the first year her car got to sit in a heated garage, previous to that it was always parked in an unheated garage, or in the driveway.
In the first winter (2017) I had my new tractor, the first time it got *cold*, it killed the OEM wet cell Interstate brand battery dead as a door nail. I put in a red top Optima in December of '17. It's still fine. Never needed a jump start, or had an issue of any kind. Even now, it sits in an unheated steel building and will start on the first try even at -40F. Sometimes it will go a month without being started. Never failed to start, never needed a battery maintainer, battery heater or anything.
Last week I put a red top Optima in my '12 Ford truck, after the second time the Interstate AGM I bought in '17 was stone dead due to the cold. Truck sits outside all year 'round, brand new red top started it up like no big deal when the garbage Interstate battery whimpered and died. Both times the Interstate battery puked, I went out and fired up the tractor with the red top Optima in it, and drove it over to jump start the dead Interstate.
Your "facts" that "everybody knows" don't add up.
Nothing new there.
If those Optima batteries didn't work, I wouldn't buy them. They've never failed me in 20 years. The only ones I'm done with are Interstate. They'll never get another dime of my money. They refused to replace the AGM last winter when it died, because they had to charge it overnight (in a heated shop, naturally) before they would "test" it to see if it was "bad". Well, surprise and shucky-dang, it "passed" when it was warmed up from being inside all night. This year when it died again (seems the magic "cold" number is always about -30F or colder), I didn't even call them. I just went down to Napa and bought the Optima.
I have no use for a battery that won't work at -30F or below.
   / Kubota engine difficult to turn over when cold (not battery) #25
Whatever. I actually 'unlocked you comment to read you reply. Probably shouldn't have. Being as 'Battery Smart' as you are, I'm sure you know that cold don't kill a flooded cell jar, heat does.
Keep on trolling, it's always interesting.,..
   / Kubota engine difficult to turn over when cold (not battery) #27
Awwwww…guys…..can’t we all just get along? LOL
   / Kubota engine difficult to turn over when cold (not battery) #28
I would think a voltage drop test is in order now.
   / Kubota engine difficult to turn over when cold (not battery) #29
^^^ Voltage drop testing! If the battery is good then it's cables or starter. (ruling out oil because temps aren't low enough to be an issue) Regarding starters, yank them and pull them apart and clean and lube and they'll likely work like new (of course, check brushes, but generally starters end up being arthritic, in need of cleaning and lubing). And just to cover everything in order to have great starting: verify your glow plugs are good (NOTE: I'd never look to engage GPs for 60 seconds unless you want to blow them out (swell them up and get the stuck or blow out a tip).
Need cranking speed and temps (cranking speed will bump up cylinder temps, but GPs are what are necessary to really light off).
   / Kubota engine difficult to turn over when cold (not battery) #30
Strange, the only times that a battery has died on
me is in the winter they always work fine in the
summer but winter its a different story
willy
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2023 Kubota SVL97-2 Compact Track Loader (A55315)
2023 Kubota...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
Year: 2014 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
