Batteries! How weird they are...
   / Batteries! How weird they are... #11
"Matching" is not the answer to charging a battery.
I'm sorry. It's an innovative, but probably incorrect.
There is a minimum size (ampacity) battery required to turn the starter and start the engine. Any larger capacity battery will simply do the same thing for a longer time. "Matching" the charging system to the battery capacity is not real.
Everything you are seeing and measuring could also be due to a large battery that is able to develop cell voltage, but is not able to store much of a charge (amperage) in those cells. A possible cause for that is something in one or more cells is not allowing the plates to use their full area to store charge. The plates may not be properly isolated, there could be uneven sulphation due to how it was stored, or it may simply be one or more cells have a low amount or acidity of electrolyte.
Science starts with the simplest theory that explains the facts. A poorly built battery makes more physical sense than the electrical matching idea.
rScotty
"Science starts with the simplest theory that explains the facts."
This principle is often referred to as "Occam's Razor"...
   / Batteries! How weird they are... #12
I posted only trying to help. As I said I had the new battery professionally tested. One thing I forgot to mention which eliminates the large battery and science theory is I replaced that with a known good car battery.
Same results! At first it started tractor great so I thought my troubles were over, but nope...same results, a downward spiral of ever slower cranking.
That's why I said in title how weird they are!
Logically the higher cranking amp battery would start better, more capacity, etc. which I'm sure it is.
Reality is the small battery starts Cub so well, now it starts Economy well.
Bottom line is it all has to match apparently, and maybe help someone.
   / Batteries! How weird they are... #14
Sorry No, bigger battery's will start things better and longer, if everything is equal, something is obviously not equal here.
thats like saying a AAA, is better then a AA, its simply not if all things are equal.
   / Batteries! How weird they are... #15
"Matching" a battery is kinda like fools gold.
Idea may look good, but it ain't reality!
  • Good Post
Reactions: JWR
By match I mean it should be as original for application as possible. I'm finding out a 20 amp charging system isn't a match for a high CCA battery.
No different than putting a 1/2 hp pump in a 500 ft deep well.
Again...only trying to help others by my many hours trial & error. I know what works.
   / Batteries! How weird they are... #17
It could be that the higher capacity battery does not have enough run time for the low output charging system to fully charge the battery. Other accessories could be taking away from the charge as well.
But yes, given the proper time and if the battery is in good shape it should eventually charge to full capacity.
I thought that also, but even without any accessories on lights or PTO clutch I can only get 13v max full throttle...usually 12.7-12.8v.
   / Batteries! How weird they are... #19
Changing battery solved the problem though! Changing back to large battery the problem reappeared.
What's going on is the stator+diode/regulator system is not able to keep the 700CCA battery charged and running like that voltage is low.
Using 300CCA battery the stator+diode/reg module is matched. It now runs at just over 14 volts, keeping battery charged and since the voltage is a little more cranks better.
I've spent many hours of experimentation and if I were to use large battery in Cub it would act like the Economy over time. Battery is so large I'd have to fabricate some way mounting it. It would crank Cub fine at first, but the Cubs same charging system wouldn't be able to restore that battery. Over time same thing, lower voltage gradually, lower running voltage (dim lights), until hard starting. Higher voltage means faster cranking, hotter spark, brighter lights, etc.
I'm telling all this hoping it may help someone. Over the years I've discovered some things you think would be an improvement like higher CCA battery may have opposite effect.
"Static" volts on a fully charged battery should be around 13.2 V or better.
Could be the larger battery was simply never fully charged. Try giving ti a full charge using an actual battery charger. It will take a lot longer for a large capacity battery that is not fully charged to come up to "normal" voltage just using the charging system on the vehicle. The measured voltage will be lower until it comes up nearer to full charge.
Does seem odd the smaller battery while reading lower in volts while cranking, seemed better. Was the cranking speed noticeably faster with the smaller battery or did it just fire sooner?
   / Batteries! How weird they are... #20
Want battery matching??... Its a joke.... look at you jump box, it has maybe a 12 amp hour capacity (small gel cell battery (non lithium-ion battery)) but it will jump start a big V8 motor... What you don't seem to grasp is a battery will dump all its chemical energy to meet demand until it self destructs....
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
205196 (A52706)
205196 (A52706)
2003 Big Tex 10PI...
