Bass ackwards snowblower
/ Bass ackwards snowblower #1
farmyid
Bronze Member
Western Mass at 1500 feet elavation
Century 3040
Well I got the driveline lengthened just in time for the big snow (actually a bit less than we expected at 18") cranked that baby up started backwards and.... lots of snow churning around but not that much coming out the chute! Took me quite a while to figure out what the problem was. The guy that sold it to me explained that he had replaced the gearbox with the wrong one and that his 540 RPM blower now needed to be turned at 1000 rpm. Well, that's not it. The problem is that although the second stage impeller is going the right way the auger is not!!! It sends the snow out to the ends of the blower. So - what I am thinking about doing is taking the auger out and flipping it over. that will put the rotation ok - but I will hve either remove the drive gear and put it on the other end or perhaps leave it on the end it is and just put a new one on the other end. I am hoping the genius welder who lengthed my drive shaft will come to the rescue again. Cool machine, huh? Any suggestions on how to make it easier appreciated! Also where to get a gear sprocket about 7" diamete? It's an old (probably thirty years) Intenational 6'-6" blower Farmyid (Mark)
/ Bass ackwards snowblower #2
Without taking the gear box apart, you will not know. I ran into that problem once with a rototiller. It was as easy as opening the gear box and flipping some gears. On another, that wasn't possible. It is a while ago that I had done this, so all the details of how I had done it are lost to an old mans memory. The only thing that I do remember is that it had to do with flipping the gear and reversing the gear that drove it on the shaft. What I don't understand is how the second stage auger can be turning in the correct direction, but the feed auger is turning back-wards. Possibly he had this entire unit apart and only half of it isn't assembled correctly?????
/ Bass ackwards snowblower #3
Mark it sounds to me as though your snow blower doesn't know if it’s coming or going. /forums/images/graemlins/confused.gif
I wish that I could be of some help to you on fixing your problem. I have a Woods myself and I have been inside the gearbox. They aren't all that complicated. I might suggest doing what the other posts mentioned and you might just figure out which gear might be in the wrong place.
"What I don't understand is how the second stage auger can be turning in the correct direction, but the feed auger is turning back-wards"
I have been wondering that as well. Of course the shafts for the auger and the impeller are coming out of the gearbow at 90 degrees to each other.
I guess I should have a look in there. I had just assumed that it must be the wrong gearbox. At least with turning the auger over I know what has to be done! This ought to be interesting. Thanks and I'll let you know what happens. Mark Leue (say Loya)
BTW If anyone who uses a Mac can give me some suggestions as to how to use the instant faces and markup I'd be appreciative (PM me)
/ Bass ackwards snowblower #5
<font color="blue"> Also where to get a gear sprocket about 7" diameter? </font>
Any farm equipment dealer should be able to help you out. All you need to do is determine the gauge of chain, it's probably schedule 50, and count the number of teeth on the sprocket. If you don't know what gauge the chain is, just measure its width and the distance between cross pins. From that your dealer will know what gauge it is. Sprockets have been standard for decades. e.g. a 50 x 48 sprocket is for schedule 50 chain and has 48 teeth. But your shouldn't have to do this.
I'll bet the gear box was put in upside down. Many gear boxes are made to be installed either way. If the gear box is upside down the impeller would turn the right way and the auger the wrong way. For this to be the problem there would have to be output shafts on both sides of the gear box turning in opposite directions.
/ Bass ackwards snowblower #6
Are you sure if you turn the auger over it will change direction?
I took a piece of spiral pasta and turned it over and it looks the same to me. I also bent up a wire mock-up and it also looks the same. /forums/images/graemlins/frown.gif
/ Bass ackwards snowblower #7
Yup, flipping the auger would correct the direction. I'm wondering if it is a gearbox originally intended to be driven off the front crank turning a front blower? No, I guess that wouldn't be right either!
/ Bass ackwards snowblower #8
Yeah, I forgot the auger pulls from BOTH sides towards the inside. If it was just a spiral from one end to the other it wouldn't work. Hey, I learned something new, today. /forums/images/graemlins/laugh.gif
/ Bass ackwards snowblower #9
When I had my Woods snow blower completely disassembled to repaint it I found out the auger could indeed be reversed and put in wrong if someone was not paying attention to details. Maybe yours just got put together wrong? /forums/images/graemlins/frown.gif
"I found out the auger could indeed be reversed and put in wrong if someone was not paying attention to details. Maybe yours just got put together wrong? "
Not a chance on mine. The drive sprocket is welded onto one end and a collar on the other. I took it down to a place that said they had expierience with these kind of gearboxes today and they said they'd look at it tommorow. they confirmed what Junkman said; some of these gearboxes have a way to reverse the rotation by changing position of the gears. Wouldn't that be cool....
I also spoke to the guy I bought it from who was very embaressed. He even made noises like he wanted to help out with the cost of the repair - something that I would take to be a very upright and honorable thing to do. I'll let you know what happens. Mark
/ Bass ackwards snowblower #11
Farmyid
If someone had the gear box on your snowblower apart, they put it back together wrong. There should be two bevel gears in the gearbox to put power to the flutes that move snow to the blower. Open the gearbox and check the gears. One of the bevel gears has to be moved to the other side of the other bevel gear "on the same shaft" to change the direction of the flutes.
Bud
/ Bass ackwards snowblower #12
Farmyid
Sorry I couldn't get back to you sooner. I tried to reply to you when this thread started but could not open reply. Today I found I had a problem with cookies. Got it straightened out, and sent a reply. A little late. Sorry
Bud
Just to tie up the loose end of the thread (so to speak) The gear box was siezed onto the impeller shaft so tight That the gear box repair route was ruled out.My buddies at the repair shop ended up cutting the sprocket off the auger shaft and rewelding it on the other end, thus flipping the whole auger over. They charged me $124 (2.6 hours although I know for shure they spent a lot of time trying to get the gearbox seperated from the impeller) The guy that sold me the blower just paid the whole bill, which I consider very honest of him. Mark
/ Bass ackwards snowblower #14
Where is this "repair shop"..... at those prices, I have a whole lot of work that they can do for me..... It would be worth the drive.... glad that it worked out for you and that you can now blow snow into the next county....... /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
/ Bass ackwards snowblower #15
that's about 45$ and hour, that's what we chage at our machine shop, but ours is in canadian funds...
/ Bass ackwards snowblower #16
So whats that work out to in US funds,...... About $6.75! /forums/images/graemlins/blush.gif
The repair shop is called C and A repair and I knew I was in the right place when I saw their inventory of drive line parts annd other common tractor bits arranged in isles in the customer accseible part of the store. They are in Whately, MA right along the Connecticut river. They are a Cub Cadet dealer as well. I am really happy with the work they have done. BTW tge next county DOES have a border with my land so if I cut a new road back to that part of the property I could actually try that :)
2006 Mitsubishi Endeavor (A61569)
2006 Mitsubishi...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2010 Ford F-150 Crew Cab Pickup Truck (A61568)
2010 Ford F-150...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2015 John Deere 210G Hydraulic Excavator (A61567)
2015 John Deere...
2012 Caterpillar 924K Articulated Wheel Loader (A61567)
2012 Caterpillar...
