Basement Project
/ Basement Project
Thanks for the tips and words of encouragement guys. I got all the corner bead up yesterday and pulled the dead-end screws out. I love it when my calculations work out... I figured 18 pieces of corner bead, truly a walking around estimate. Got to the big box yesterday, complete with holiday crowd and picked up what I needed. The cashier counted my corners at 19. I said, "go ahead, I'll surely need one more". Finished up with exactly one left!
I have a cheap tape banjo that does a remarkably good job if the mud is thin enough. My scaffold is out on loan, due back today I hope. Guy doesn't have a truck though, so I'll have to make the run just to get it. I'm wishing I had some stilts, maybe I'll check into renting.
Stay tuned for more pics /forums/images/graemlins/smile.gif
/ Basement Project
Here's the progress of the day. I got all the flats and corners taped below ceiling level. A couple of low ceilings I could reach so they got it too. Went through one 500 foot roll of tape plus a partial I had.
Took #2 son to lunch and checked a couple of rental places for stilts. No go. I'll either check with a specialty place or do without. Got home and my bud called for me to pick up my scaffold so that will be the ticket.
Tomorrow I'll finish the taping including the 45 degree walls. I like a product called stait-flex for those corners. It's tape that must have a thin metal layer. It holds a crease and keeps odd angles straight. I'll also get a first coat on the corner bead. That should be enough for a day /forums/images/graemlins/smile.gif
/ Basement Project
Well, it was a successful weekend. I got the corner bead on, all the joints taped and the corner bead mudded in. Here's a shot looking over the bar. My workshop door is to the right and the bathroom door is to the left /forums/images/graemlins/smile.gif
/ Basement Project
And here's my shop, looking towards where my workbench will eventually sit. I hope the next coats will be a little faster without the tape and corner bead to worry about. That will have to wait until next weekend I'm afraid /forums/images/graemlins/smile.gif
/ Basement Project #25
A friend of mine recently used an Idea I saw somewhere years ago. Take an old pair of shoes and screw them to two empty five gallon buckets. You may have to put a board in between for some grip for the screws.
You have to be careful where you step and climbing stairs is out of the question but they are cheap to make.
/ Basement Project
Scott, I LOVE that idea! Thanks. I believe I'll be on my own stilts next weekend /forums/images/graemlins/smile.gif
/ Basement Project
<font color="blue"> Was that a martini in the first picture of this latest batch? </font>
Hey, after 144 feet of corner bead, 700 feet of tape and 15 gallons of joint compound I felt like I deserved it. Right now my back is reminding me of it all /forums/images/graemlins/smile.gif
/ Basement Project
OK, just so no one thinks I'm slacking off on a dreary pre-winter day here's the progress. I won't bore you with too many pictures. For those who have been involved in drywall finishing, the in-between pictures aren't very exciting. Today I got most of the second coat on. Started with the tapered joints, then the inside/vertical corners, then the inside/horizontal corners, then the buttt joints (few), then the outside corners. I have an our or so to finish tomorrow on outside corners, all horizontal. Oh yeah, somewhere in there I did the screw heads in the fields.
This pic is the doorway into the half bath in the bar area. The shadow on the wall is from my halogen lamp visible in the next picture /forums/images/graemlins/smile.gif
/ Basement Project
Same shot, a bit wider. I forgot to adjust the white balance so it's a bit on the warm side. Yet another thing to remember on this camera /forums/images/graemlins/smile.gif
/ Basement Project
Well again, I won't bore with too many pictures. Today I finished the third coat of drywall mud so it's ready for sanding. I also picked up the doors at the big box as they were on sale. Don't need them just yet but I couldn't pass up the price. And I also couldn't resist the temptation of slipping them into place. The door to the right is my shop and to the left is the bath.
Sanding is next but it will likely wait until after Christmas now /forums/images/graemlins/smile.gif
/ Basement Project
And one final shot of the tools of the trade /forums/images/graemlins/smile.gif
/ Basement Project
Finally, back on track after the holidays. The next step is by far the worst... sanding drywall. First order of business is to seal off the rest of the house. Some plastic sheeting, tape and a few sticks of wood is all it takes /forums/images/graemlins/smile.gif
/ Basement Project
A fan in the window ensures a bit of negative pressure /forums/images/graemlins/smile.gif
/ Basement Project
The sealing arsenal includes painters canvas drop cloths which work very well on the stairs and not as slick as plastic /forums/images/graemlins/smile.gif
/ Basement Project
The real star of this phase was not a person but a rented tool. I used a Porter-Cable dustless drywall sander and it was worth every penny of the rental. It captured most of the dust and saved tons of time as the sanding disc is powered. The wand was long enough to eliminate ladders though it did get a bit heavy later in the day /forums/images/graemlins/smile.gif
/ Basement Project
Corners still require hand sanding as the power sander won't get all the way in. It leaves about 3/4 inch but a 90 degree sanding block makes quick work of it. Of course, it also makes a mountain of dust /forums/images/graemlins/smile.gif
/ Basement Project
In spite of a hat, dust mask and throw away coveralls some dust still manages to coat yours truly. Nasty stuff /forums/images/graemlins/smile.gif
I took Friday off for the sanding and textured the ceilings Saturday. Today was company so priming will wait until next weekend. I'll spray a coat and spray a finish coat on the ceilings /forums/images/graemlins/smile.gif
/ Basement Project #40
</font><font color="blue" class="small">( sanding block )</font>
I think, of all the tools I've used and work I've done, in my lifetime, I hate sanding more than anything, especially with non-powered sandpaper, whether with or without a sanding block. /forums/images/graemlins/laugh.gif
