Barrel Ballast
   / Barrel Ballast #1
bunkydad
Kingston, New York
Kubota L3560 and Mx5400
Converted a smaller rear ballast box that came with my old tractor (Kubota B7510) for use with my new one (L3800). I cut out the back of the box and make a support for the barrel. My plan is to fill it with steel and cement to get it to about 1000lbs. I think that's the recommended weight that I've seen from reading some of the posts.
I've looked through a bunch of old posts and will most likely put some tubing to hold tools and a rear hitch on it before I fill it. Any recommendations or suggestions before I start mixing the cement would be greatly appreciated.
I know its not pretty... rear ballast barrel (1).JPGrear ballast barrel (2).JPGrear ballast barrel (3).JPGrear ballast barrel (4).JPGrear ballast barrel (5).JPG
   / Barrel Ballast #3
I'm guessing that your 3pt will reach that low even when your tractor is sitting on top of a foot of snow or ice so there will not be any issues getting it hooked up in any conditions?
A Californian only thinks like that because he formerly lived north of the border. ;)
I'm always thinking multi purpose use so I would think a concrete filled barrel on its side in the form of a 3pt roller would have some additional utility.
Just thinking out loud, your too far along to want to redesign it probably.
   / Barrel Ballast #4
Id throw in some rebar or scrap steel into the concrete to stiffen everything nice.
   / Barrel Ballast
The 3 point on the tractor lowers to about 2 inches above the ground so I think (hope) that it should be enough.
   / Barrel Ballast
will do. I have some wire mesh from an old slab pour that I will put in before I fill it. thank you
   / Barrel Ballast #8
If you can add a receiver to it you will find it handy.
L2800 w/FEL - 72" Land Pride rake
   / Barrel Ballast #9
Exactly, thank you. I have a quick hitch so the weight will be a little further back.
My hacked in top link was not high enough, adding some links to extend it 6 inches or so, so check your geometry, i guessed on mine
   / Barrel Ballast #10
I put some rebar and 3pt mounts in a 55 gallon drum and filled it with concrete for my old IH2500b. It weighed nowhere near 1000#. I could tip it over on its side and then I could tip it back up on its end by myself and I don't consider myself a strong man. Concrete weighs a little over 100# per cubic foot. Steel weighs around 500# per cubic foot. So be sure to put enough steel in it to make it worth the effort to construct. ;)
BESTWAY AG VSK50 LOT IDENTIFIER 7 (A53084)
BESTWAY AG VSK50...
LOAD OUT INFORMATION LOT IDENTIFIER 4 (A53084)
LOAD OUT...
PALLET OF VIGORO HD FABRIC & GARDEN STAPLES (A51248)
PALLET OF VIGORO...
PALLET WITH TROYBILT TBE304 EDGER (A51248)
PALLET WITH...
10' DISC HARROW (A51247)
10' DISC HARROW...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
