Barndominium/Shop or "real" House?
   / Barndominium/Shop or "real" House?
Always a good idea to incorporate flexibility to allow for easy changes in use as our interests evolve in life.
If you were ever in a wheelchair (hopefully not), why would you want to go somewhere else instead of staying at the property you worked so hard to have?
I'm project/hobby orientated. If I was in a wheechair this property would no longer facilitate that. In fact it would be rather taunting IMO.
   / Barndominium/Shop or "real" House? #292
I believe you are smart enough to figure a way when no one else could.
I suppose worst comes to worst I would park a mobile home, connect power water and septic to it if I became incapacitated to the point I can't go up some stairs.
   / Barndominium/Shop or "real" House? #294
You obviously have the talent to design your space today in a way to make it easier to adapt in the future if your interests or needs change.
Honestly I'd rather plan to so something like this:
Id rather not have to compromise on my Barndo design now for something that may never happen. I'd have the space and utilities hookups available if I needed to do this. Then rent out the other living space or something.
And having that space available for a future house could make the property more marketable if I was forced to sell for some reason.
So like, this wouldn't work if you extended in to two bays? If that roof line of the garage was southern, you have both the solar and the water collection cistern solved.
That thing is probably more expensive than my stick frame design.
One builder I was talking to gave me a copy of a contract he just signed in Jan 2022.
It was a 1200 sq-ft ranch with a 400 sq-ft garage. A simple gable roof along the entire structure, no valleys. Standard forced hot air heat, formica countertops etc. $324,000...
That design would be in the $400k range easy. I'm hoping my Barndo is under $300k price tag.
I did find one plan that I somewhat liked: 94015
Except I wanted to add a basement. I was told it would be around $450k. That's about when I seriously started to design a Barndo.
   / Barndominium/Shop or "real" House? #298
   / Barndominium/Shop or "real" House? #300
There was one called the Duckworth, on this site - long ago, but it seems to have been removed. If I was to do a spec house.... that would have been the plan used. 321-602 looks to be a very solid and usable configuration.
I'm saying, I would not build a Barno for safety and getting older issues. But you could get the Barno into your cost set, if you wanted to. You just have to be the General Contractor and make the materials purchases.
2008 International 4400 Pumper Fire Truck (A50323)
2008 International...
Caterpillar 345D Hydraulic Excavator (A50322)
Caterpillar 345D...
Yale Veracitor 135VX Yale 12,150lb Forklift (A50322)
Yale Veracitor...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
Club Car Carryall 500 (A50121)
Club Car Carryall...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
