Bar oil quality
   / Bar oil quality #101
Same on the bar oil, run down to Madsen's pick it up. They usually have a pretty good price on it. I'll have to check out the pre mix next time i'm there.
My daughter bought a chainsaw, and a can of pre-mix gasoline.
She used the saw once, the pre-mix sat in the garage for over 5 years.
I brought the pre-mix home, and had it on a shelf, I was going to use it to light a brushfire,,,
Well, I had a small gas engine that would not start,, I knew I needed to prime the engine,, I remembered the pre-mix,,
I tossed a little premix in the carb, the engine started right up!! WOOT!!
It was sure easy using that small can of gasoline,, and it was perfect for starting that engine!!
   / Bar oil quality #102
Don't have a clue what Stihl uses for stabilizer but it sure looks like Marine Stabil. I do know the red stinky stuff is worthless.
I top off all my tanks in the fall and in the spring, they all fire tight up.
   / Bar oil quality #103
I just use the 15w40 drain oil that I have, works like a charm
2016 FORD TRANSIT 350 CARGO VAN (A59905)
2016 FORD TRANSIT...
2006 Club Car Carryall 2 Electric Utility Cart (A59228)
2006 Club Car...
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59905)
1997 DORSEY...
Used Landpride GR1525 Stump Grinder
Used Landpride...
