Bar oil quality
/ Bar oil quality #101
Same on the bar oil, run down to Madsen's pick it up. They usually have a pretty good price on it. I'll have to check out the pre mix next time i'm there.
My daughter bought a chainsaw, and a can of pre-mix gasoline.
She used the saw once, the pre-mix sat in the garage for over 5 years.
I brought the pre-mix home, and had it on a shelf, I was going to use it to light a brushfire,,,
Well, I had a small gas engine that would not start,, I knew I needed to prime the engine,, I remembered the pre-mix,,
I tossed a little premix in the carb, the engine started right up!! WOOT!!
It was sure easy using that small can of gasoline,, and it was perfect for starting that engine!!
/ Bar oil quality #102
Don't have a clue what Stihl uses for stabilizer but it sure looks like Marine Stabil. I do know the red stinky stuff is worthless.
I top off all my tanks in the fall and in the spring, they all fire tight up.
/ Bar oil quality #103
I just use the 15w40 drain oil that I have, works like a charm
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
Cummins 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2026 tilt trailer (A56859)
2026 tilt trailer...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
