bank trimming?
   / bank trimming? #1
ykpowers
hillsville va
49 ford 8n
I have several areas on the property that I have been trimming by hand, but that may not be the best way....
Case:1 small creek about 4' wide. It has channeled down about 2 Ft would a sickle mower work well to cut this flush across?
Case 2: 45deg bank with road directly below and on top. Can you run a sickle at a 45deg angle or does it have to be flat?
   / bank trimming? #2
Both of your cases can be satisfied with a sickle. However, you will need a newer one that is BELT driven. Most, if not all, belt driven sickles can work from 90° up to 70° down. The old Pittman driven sickles don't have the working range you need. Some used ones that are capable of doing the job .... JD 350, Case/IH 1100, Ford 915 and there are others.
   / bank trimming? #3
Would this idea work for you? Unfortunately I'm not skilled enough to rotate the image but I'm on about a 45 degree slope with no danger at all of tipping.
   / bank trimming? #4
Man - what a let down. I thought this was going to describe ways to recoup funds that the banks charge. Sorry
   / bank trimming? #5
Maybe it should be. Sooner or later that would pay for a new sickle mower.
2024 KMC 7406 (A53084)
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
RoGator RG1100C (A52748)
RoGator RG1100C...
Engel 20' Boat (A50121)
Engel 20' Boat...
