Ballast weight......UGHHHH...HEAVY
/ Ballast weight......UGHHHH...HEAVY #1
Chain Bender
Kubota L3200
Well I went ahead an hooked the ballast barrel up to the FEL to move it out from under my shop. FEL lifted it with no problem. But when I went to back out from under the barn, the tractor wouldn't move. I thought it had jumped out of gear or the brake was still on. Nope, I was in 2 WD and the left rear tire was off the ground! I put in 4 WD and backed out slowly and lowered the barrel as soon as I got it off the floor of my shop.
As you can see by the pictures it is heavy and the left rear tire is almost off the ground in this picture. Sitting where it is, it won't move in 2 WD.
The barrel is hung about 4" in front of the bucket blade and the bucket is tilted as far back as it will go. Don't know how much the KK 5' bush hog weighs, but than goodness I still had it on the tractor. I think it's going to be all the ballast I will ever need! :)
CB
/ Ballast weight......UGHHHH...HEAVY #2
Better try re-attaching the pics:thumbsup:
/ Ballast weight......UGHHHH...HEAVY #4
What's wrong with them? They look fine on my screen.
CB
Maybe it is just my computer but I dont see ANY pictures attached at all.
Anyone else???
/ Ballast weight......UGHHHH...HEAVY #5
I see 2 pictures
James K0UA
My neighbor just stopped by to show me a new used trailer he had bought. Blah Blah Blah.... then I showed him the ballast weight I had put together. He warned me to be careful that I didn't wear out my hydro pump.
He had a tractor almost identical to mine but now has an 81 horse (I think) Kubota of some kind. He's been a farmer all of his life and had all sorts of tractors and I trust his opinion and advice.
My max lift at the balls on the lift arms is 1998#. I think the barrel is going to weigh around 800#.
Anyone had any troubles with their pump while hauling around their "weights"?
CB
/ Ballast weight......UGHHHH...HEAVY #7
Well I have only had my 750 lb or so barrel on for a little over a year, but no problems yet. It stays on about 90 percent of the time. Only comes off for mowing, which the type of mowing I am talking about (brushcutting) is just a few times in the summer and fall. I really like having it on there, as I do a lot of loader work, and I like the space to haul a few things in the top and the handle tools in 2 inch pvc inside. and the 2 inch receiver on the back.
here is a link, pictures on the first post
http://www.tractorbynet.com/forums/build-yourself/199329-look-what-i-built-today.html
James K0UA
James K0UA
Nice,
I didn't make mine that fancy. I just filled it up an left some room on the top for junk. May wish some day that I had spent the extra time and did what you did. I can always make another one fairly cheap too. I have several more barrels.
CB
/ Ballast weight......UGHHHH...HEAVY #9
I see them now too:thumbsup:
/ Ballast weight......UGHHHH...HEAVY #10
Nice ! I ever have taken a look at this tractor,yeah it is a nice tractor but a little heavy.
/ Ballast weight......UGHHHH...HEAVY #11
I put chains running from the lift arm bolts up to a pin in one of the top link holes so the hydraulics are not always working.
/ Ballast weight......UGHHHH...HEAVY #12
The hydraulics are not doing anything with the 3 point unless you are moving the lever. Otherwise, the lift ram is sealed and the fluid inside is holding the 3 point up. The pump will not wear out from having a heavy weight on the back. You could theoretically blow a lift cylinder seal, but that is unlikely as long as you are not bouncing a weight larger than your max lift on the 3 point.
Aaron Z
/ Ballast weight......UGHHHH...HEAVY #13
Something to be aware of that I don't fully understand but someone here, Soundguy?, can explain, I'm sure:
I build a barrel just like yours. The draft arm pins are centered in the barrel such that it's balanced & little to no weight on the toplink most of the time. Somehow I got into draft mode & the toplink draft valve lifted the arms until my toplink had a 90 degree bend? The arms would not go down until I drove out the toplink pin & relieved the pressure. I built a pipe toplink with a 90 degree bend to provide clearance & never had a reoccurance, have since traded tractors. :confused: MikeD74t
BTW: when carrying that type of load, I run the chain behind the bucket to carry the weight closer to the tractor. Easier on the rig overall.
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
1984 BOMAG MPH100R SOIL STABILIZER/RECYCLER (A60429)
1984 BOMAG MPH100R...
17102 (A56859)
17102 (A56859)
