Ballast Box
   / Ballast Box #1
PaulInMi
South-Eastern Michigan
Kubota 3010HST
Recently there was some discussion on rear ballast and ballast boxes, so I figured I would show what I rigged up until I can get my box blade;
Carry-all fork from TSC plus 3 80lb and 3 40lb bags of softner salt.
Plus the Carry-all will come in handy for numerous other things.
Happy New Year Everyone/w3tcompact/icons/smile.gif.
Let me know if people are getting sick of my pictures/w3tcompact/icons/crazy.gif.
   / Ballast Box #3
Paul, the carryalls are great. Real useful. Make decent pallet forks too.
   / Ballast Box #4
I've been thinking about getting a carryall. Do they actually fit and work good as pallet forks?
   / Ballast Box #5
Paul,
The more and more I see also read about those carry all,and when things quite down around here...yep plan on building one.
Keep the photos coming. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / Ballast Box #6
Jim, they work for average pallet work. It can be close fit sometimes. Made from angle iron. I've seen them damaged with too heavy a load such as crates full of cabbage. There is a weight rating to them, under a 1/2 ton. That was fine for me as the lift cap on the 4100 is only 930#. The ones designed exclusivly as pallet forks are made of box steel with tapered ends. They cost more but are both stronger and longer.
   / Ballast Box #7
my ballast comes from a TSC carryall and a 55gal. drum filled with water and used antifreeze. sometimes i use a piano for ballast.
kevin
   / Ballast Box
Redhawk-
That looks like a great set-up as well. Mine is a 44gal heavy-duty trash can. I thought about filling mine w/water also, but the hose in my garage is frozen right now(gotta love MI weather/w3tcompact/icons/smile.gif).
Happy New Year.
   / Ballast Box #9
Paul, the nice thing about the 4x4 (wings) sticking out is that i can set the barrel down on a double set of 4x4's and drive away with the carryall still attached.
redhawk
   / Ballast Box #10
Thanks for the info. I noticed in some catalogs that the carryall and 3 point pallet forks both cost about the same. Would pallet forks be more versatile or not? I too have a 4100, so the 1000 pound capacity is well suited to the limits of my tractor.
2025 CFG Industrial QK16R (A50123)
2025 CFG...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2009-2014 Ford F150 Pickup Bed  (A52384)
2009-2014 Ford...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
