Ballast Box
   / Ballast Box #1
PaulInMi
South-Eastern Michigan
Kubota 3010HST
Recently there was some discussion on rear ballast and ballast boxes, so I figured I would show what I rigged up until I can get my box blade;
Carry-all fork from TSC plus 3 80lb and 3 40lb bags of softner salt.
Plus the Carry-all will come in handy for numerous other things.
Happy New Year Everyone/w3tcompact/icons/smile.gif.
Let me know if people are getting sick of my pictures/w3tcompact/icons/crazy.gif.
   / Ballast Box #3
Paul, the carryalls are great. Real useful. Make decent pallet forks too.
   / Ballast Box #4
I've been thinking about getting a carryall. Do they actually fit and work good as pallet forks?
   / Ballast Box #5
Paul,
The more and more I see also read about those carry all,and when things quite down around here...yep plan on building one.
Keep the photos coming. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / Ballast Box #6
Jim, they work for average pallet work. It can be close fit sometimes. Made from angle iron. I've seen them damaged with too heavy a load such as crates full of cabbage. There is a weight rating to them, under a 1/2 ton. That was fine for me as the lift cap on the 4100 is only 930#. The ones designed exclusivly as pallet forks are made of box steel with tapered ends. They cost more but are both stronger and longer.
   / Ballast Box #7
my ballast comes from a TSC carryall and a 55gal. drum filled with water and used antifreeze. sometimes i use a piano for ballast.
kevin
   / Ballast Box
Redhawk-
That looks like a great set-up as well. Mine is a 44gal heavy-duty trash can. I thought about filling mine w/water also, but the hose in my garage is frozen right now(gotta love MI weather/w3tcompact/icons/smile.gif).
Happy New Year.
   / Ballast Box #9
Paul, the nice thing about the 4x4 (wings) sticking out is that i can set the barrel down on a double set of 4x4's and drive away with the carryall still attached.
redhawk
   / Ballast Box #10
Thanks for the info. I noticed in some catalogs that the carryall and 3 point pallet forks both cost about the same. Would pallet forks be more versatile or not? I too have a 4100, so the 1000 pound capacity is well suited to the limits of my tractor.
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
Bad Boy Pro Z Zero Turn Mower (A53117)
Bad Boy Pro Z Zero...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
