Ballast Box
/ Ballast Box #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I read an add on Craigs list this morning about a used, dirty, ugly ballast box close enough to me for $300. I called him thinking it had to be a typo that he had over looked. " Nope " he said, "that is the price". I have been kicking around getting one for a long time so after I said good-by to him I called up my friendly Deere dealer and ordered a new one. $216 plus $71 for a bushing kit. Oh, by the way, my dealer lets me pay full retail price on every consumer item I purchase. BUT it is still cheaper than that guys old beat up one.
Some people think their stuff is really good.
/ Ballast Box #2
Maybe the guy was operating on the principle that "if you tell a big enough lie people will believe it"? :confused3:
/ Ballast Box #3
If it was lined with silver it was a good deal. Sometimes you have to ask the important questions.
/ Ballast Box #5
Like...was this a scam and I'm just missing the sarcasm? Or did some one really think they were going to get $300.00 bucks?
:confused2:
/ Ballast Box
:confused2:
No, he was serious and wasn't going to budge because he thought new ones were a lot more money.
4 hours later I seen he had lowered his price to $200 but that is still to high for one that is all beat up.
/ Ballast Box #7
$300 for a used ballast box is tantamount to robbery!
I bought mine, a Deere box filled with sand, for $90. It was about 2-3 years old and had never been used. That was a good deal...but a really used ballast box should go for well under a hundred bucks.
/ Ballast Box #8
Some people...
The bushing kits should be a lot cheaper than that! Was is BW15056 that he quoted?
TSC also sells them, as well as: QUICK HITCH ADAPTER KIT CAT 1-3
/ Ballast Box #9
I built mine for well under $100 and that includes the barrel the hardware and all the cement. sure I had to weld up and cut a few things, but it is a "level 1" project, not too difficult.
James K0UA
/ Ballast Box #10
I saw that one, looked pretty steep to me! Besides, it would have been a 2-1/2 hour drive for me! :( ~~ grnspot110
/ Ballast Box
Some people...
I have no idea what he ordered, I did it over the phone. Below is from JD's "build your own" web site.
iMatch / Quik-Coupler Bushing Kit BW15056 $71.00
/ Ballast Box #12
I just purchased a 2010 3520 w/FEL and considered a ballast box but I went with a 450 lb. 72 in rear scape blade. JD was offering a 700 dollars off on two implements so the FEL counted as one and I went with the blade. I thought I might as well get something I can use instead of a box with no use besides weight. Yes you have to watch what you're doing when you back up or swing around but you should be doing that anyway.
JD 3520 w/ FEL and 72 in. rear blade
Kubota ZD28 60 in.
Gravely 14 hp Kawasaki 50 in. walk behind
Stihl pruners, string trimmers, blower
18' Landscape trailer
14' Heavy Duty Trailer
JD 4010 w/ 10.5' Bush Hog
JD F-620 54 in.
2000 Chevy Silverado 1500 Z-71 4x4
2001 Chevy Silverado 2500 HD 4x4
Landpride FSP 1000 3 pt. broadcast spreader
/ Ballast Box #13
Problem is, 450 lbs isn't much weight for ballast...read your loader manual.
/ Ballast Box #14
My little 2520 has 1,000 lbs in ballast box, and it will still pick the back end up a little if I try to lift huge load with loader.
450 lbs is better than nothing, but you will find that you need alot more than that.
/ Ballast Box #15
Hmmm,this is interesting,mine won't do that. If I try to lift too much,my loader,(for lack of a better word) relieves itself. It just won't lift until I reposition.
Aren't the relief valves on all 2520s supposed to be set at the same pressures?
Greg
/ Ballast Box #16
Kubota ZD28 60 in.
JD F-620 54 in.
In all due respect a ballast box can do more for your TRACTOR than a rear blade ever will.
Go get a bucket load of wet dirt and take a peak at your front tires. I did. Scared the crap out of me as I thought both tires were going to explode right there and now.!! Not to mention the front axle.
A 3520, I would guess, should have 1000lbs. of ballast. Your manual will say.
/ Ballast Box #17
My 2520's R4 tires don't squat hardly at all when properly inflated. :cool:
/ Ballast Box #18
Greg
I'm "Guesstimating" 1,000Lbs in my box.
Its most noticable if I try to pick up something with the corner of the bucket, that picks up one of the rear tires with ease.
/ Ballast Box #19
The idea of using an implement is okay, but it needs to be heavy enough to do the job. I don't have a ballast box either but I use a 1250 lb boxblade when I need something compact behind my tlb.
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
METAL STAND (A63291)
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A61573)
2015 International...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
