Ball Size
/ Ball Size #41
L
After doing some looking at trailers yesterday, I think I'm making a mistake with a bumper pull stock trailer. They are just too tight for horses, and I'm not comfortable with trying to make it work. I've decided to get the B&W turnover gooseneck ball for my truck bed and install it myself. Then I will buy a 3 horse slant load gooseneck trailer. Probably used, and probably aluminum.
I think for the long term, this will be something that I will enjoy having instead of regret buying.
But back to ball size, I am curious why the pin that attaches that hitch isn't brought up? Seems to me that it is the weak link to everything. I would expect it to sheer before something happens to the ball.
Thank you,
Eddie
I had a recent thread about bending a hitch pin. I jerked a stump out and bent the pin. It was thru a solid bar hitch with a rubber cushion in it. It was hard to tell how bent it was after I got it out.
Eddie if IIRC you are fairly new with the horses. If you think a bumper pull is too tight wait till you start loading a slant load. Once that first horse is in its blocking your escape door. If you buy one with a rear tack area the third horse is virtually impossible to get away from if it won't step on the trailer by itself.
A two horse is meant to load the left horse first and the right horse second. Then you have the escape door to back out of. Use a trailer tie not the lead rope. If the horse starts to back out there's a chance of getting your hand caught in the knot. I almost always have someone help me load. Just in case something happens they can shut the door to keep the horse in.
Right now I have a 4 horse gn stock trailer and a 6 horse Trailet trailer with lq. I have hauled as many as 12 or 13 on a friends CM stock trailer. Take the dividers out.
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2022 EZ-GO ELITE...
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
