Ball field maintenance
   / Ball field maintenance #1
ICGREEN
Pendleton IN
JD 3520
I've inherited the church ball diamond to maintain and really don't have a clue. We have a lot of crab grass on it so I used a box blade to pull most of it off. Now I can't get the field smooth again. It's not real bad but still has some of the tooth marks from the box blade. enough to make a ball bounce crooked. What's the best way to get it back in shape. Is there some type of drag or harrow type device made for this function?
Thanks
   / Ball field maintenance #2
I've seen people use ATVs for dragging pcs. of chain link fence with cinder blocks on them. However, that's about all I know. I've always wondered myself.....
   / Ball field maintenance #3
Same thing here, chain link fence with timbers and cement blocks on them. Does a good job...
   / Ball field maintenance #4
We have used chain link as well as a metal mesh? drag. The drag had 1 inch square holes in it and was heavier than the chain link. Both worked well, but if there were bad spots we raked by hand.
   / Ball field maintenance #6
Chain link fence with a triangle of old tires tied on it, the bigger the better.
5 tires in "Olympic Rings" pattern if you can pull the width and/or the tires are small (ish).
I've heard of people just tying the tires together and towing them with no chain link underneath, but have never actually seen that.
   / Ball field maintenance #7
overseed with something that get gets green early in the season for your area,(do this in the fall of the year) then set field with burmuda or something similar that will get green in the summer keep it cut short until bermuda tales over. You might want to use a herbicide to kill weeds and unwanted crabgrass until bermurda sets up
Keep in mind I am in Tennessee not Indiana. Check with some of the local high schools or jr. college coaches they are usually pretty particular about their fields and also willing to be helpful.
You gotta love the look of the TR3 but I bet it's pricy. I've got to do it on the cheap so it looks like the fence will be the tool of choice. Thanks for the input.
   / Ball field maintenance #10
Thanks
Here's a link to a thread I did back in 2002 when I had to renovate a T-Ball diamond that was very neglected. Lots of pictures, but here are a few of my favorites...
First picture is after a couple hours work scraping with my buckets.
Picture two shows another angle.
This picture shows the results of only a half an hour of dragging a length of chain link fence with 6 concrete blocks on top of it. Pretty dramatic difference.
Not bad!
New fence. Play Ball!!! :D
2025 Swict 84in Bucket Skid Steer Attachment (A55787)
2025 Swict 84in...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2023 Yamaha jestski with trailer (A55758)
2023 Yamaha...
Giyi Hydraulic Breaker (A53316)
Giyi Hydraulic...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
