Bale spear problem; Quick attach easy with FEL/not with BS.
   / Bale spear problem; Quick attach easy with FEL/not with BS. #51
These are amazing hooking up the PTO as well as the implement! There are a few drawbacks (price, extending the implement back further from the tractor, having to cut or get new PTO drive shafts, etc.) Still incredible invention; see the videos.
Anyone know if the old simple non-PTO hardware is still made by Jiffy Hitch? Good example of simple A-frame , self centering quick hitch.
One thing I noticed about the Jiffy hitch is that pushes the implement back a lot of inches, way too much. While the European setup doesn't push the implement back at all since half of the quick hitch is built in the implement.
   / Bale spear problem; Quick attach easy with FEL/not with BS. #52
One thing I noticed about the Jiffy hitch is that pushes the implement back a lot of inches, for anyone in Europe, that's a no go. While the European setup doesn't push the implement back at all since half of the quick hitch is built in the implement.
Yes, I don't think it has to do with Europe but rather the mechanical awkwardness of having heavy implements suspended further from the tractor. The automatic connection of the PTO shafts is a remarkable feature allowing "pull up and drive away" hitch capability without ever leaving the tractor seat. I am leaning away from that luxury toward just getting a set of plain older Jiffy Hitch A-frame hardware and just manually connecting the PTOs. That only pushes the implement back 4" or so which is much easier to deal with AND the hitches must be drastically cheaper if I can locate them. Current Jiffy Hitch website never mention the existence of the simple no-PTO versions.
I know.
   / Bale spear problem; Quick attach easy with FEL/not with BS. #55
Just a thought, and you've probably done this already, if tolerances have become that tight I'd try power washing both the implement side and the loader side. I've had implements become increasingly hard to latch over time. A good clean and some grease on the pins has sometimes fixed it, sometimes not. Have a close look under the top edge lip of the attachment, there might be compacted crud under there. While I'm at it I look for any damage though haven't found any as yet.
Good trick with the oak tree, I'll add it to my repertoire of jumping up and down on it and jiggling the loader arms creatively.
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2006 Suzuki GSX-R600 Motorcycle (A55853)
2006 Suzuki...
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
2013 International WorkStar 7400 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
